Rear panhard rod bent
20 May 2025 16:56 #260509
by JimnyCol
Colombia: 2017 Jimny JB43, M13A 163,000 km, +4 cm XT suspension lift, TTS rear air diff locker, Easy Traction manual transfer shifter, AISIN free wheel manual hubs, WARN 55-S winch
Rear panhard rod bent was created by JimnyCol
How can I fix it? Around here is difficult to find a replacement rod, should I keep it like that or try to fix it...?
20 May 2025 17:48 #260510
by fordem
Replied by fordem on topic Rear panhard rod bent
You could take it off and try to beat it back straight, that's one option, or if you have access to a welder and tube you could make a replacement - there's nothing special about it, just a length of tube with an eye and a bushing at each end, just duplicate the dimensions, you could make it longer of even adjustable if the Jimny is lifted.
What I'd like to know is HOW it got bent.
20 May 2025 19:21 #260512
by JimnyCol
Replied by JimnyCol on topic Rear panhard rod bent
I really don't know how it got bent! Probably lot of offroading, and I don't know at which point it got this shape.
20 May 2025 19:23 #260513
by JimnyCol
The Jimny is slightly lifted +4 cm, the panhard rod should be the most parallel to the chassis right? so I guess it should be made a little bit shorter?
20 May 2025 22:16 #260515
by fordem
Ideally the panhard rod will be parallel to the surface the Jimny is sitting on, which in most cases will not be the same as parallel to the chassis because most Jimnys sit lower on the right side.
That said, the purpose of the panhard rod is to locate the axle "centrally" under the vehicle, the angle of the panhard rod is dictated by the suspension, from the factory the panhard rod will be almost parallel to the ground, but if the vehicle is lifted, it will sit at an angle and when that happens the axle will be offset to one side, rather than centralized. Some lift kit vendors correct this offset by providing a longer, adjustable panhard rod, but this generally causes the chassis to move side-to-side over the axle as the axle moves up/down.
The correct way to solve the problem is to move one end of the panhard rod (either one can be moved) up, if you're moving the axle end, or down, if you're moving the chassis end, to return the rod to the original position.
Unfortunately that's not quite how it works.The Jimny is slightly lifted +4 cm, the panhard rod should be the most parallel to the chassis right? so I guess it should be made a little bit shorter
The following user(s) said Thank You: JimnyCol
21 May 2025 07:13 #260519
by Motacilla
Replied by Motacilla on topic Rear panhard rod bent
+1
Any fab shop will be able to make a rod mount relocation bracket with no trouble, and will also have a hydraulic press to quickly straighten the rod.
Indeed, these things are within the scope of a shade-tree amateur -- you might be surprised how easy it is with modest investment in tools. You won't hurt anything by taking a shot at it.
Time to create page: 0.197 seconds
