Manual AC to Auto Climate Control Mod
- DavidEdie01
10 Apr 2024 15:37 #255520
by DavidEdie01
Manual AC to Auto Climate Control Mod was created by DavidEdie01
- Thank you received: 673
10 Apr 2024 16:27 #255521
Replied by DrRobin on topic Manual AC to Auto Climate Control Mod
I suspect it will be a non starter. The manual controls appear to have connecting cables which open and shut vents/valves. The automatic unit probably uses servo valves directly on the heater unit, I suspect it will be unlikely to re-use the same cables, but it might do.
The manual/auto heater control is a complete unit which includes the air vents above the controls.
Robin
Robin
10 Apr 2024 16:40 #255522
In case you are interested the auto ac heater control unit is Suzuki part number 39510-77R00-DH4 and appears to be about $400 if you can find one in stock.
Robin
Robin
- DavidEdie01
10 Apr 2024 22:01 #255527
by DavidEdie01
Replied by DavidEdie01 on topic Manual AC to Auto Climate Control Mod
That is quite interesting
25 Dec 2024 17:56 - 25 Dec 2024 17:56 #258864
by nicka.k
Replied by nicka.k on topic Manual AC to Auto Climate Control Mod
I was wondering the same thing since I always wanted a manual transmission in a Jimny, but my country doesnt import GLX with MT.
The dealership's answer to your question was "You cannot change a/c to auto climate control since the car is equipped with numerous sensors apart from the climate control panel, and it won't work without a complete setup".
I did a bit of research myself though and (sadly) that statement seems right. If you look at the rear side of the auto climate unit, there are only two pins: one for emergency light and the other for the climate "brain". However the a/c unit panel has multiple wires and pins that each control its parts (deflectors, temperature etc). So I guess we'll have to live with what we have there.
Last edit: 25 Dec 2024 17:56 by nicka.k. Reason: Typo
26 Dec 2024 08:59 - 26 Dec 2024 09:00 #258868
by Motacilla
Yes and no. You certainly can install the auto climate control in a manual control car. The catch is that it is not as simple as just replacing the panel, as your research shows.
The dealer quote contradicts itself, but the latter half is correct: one has to install the "complete setup." And that can certainly be done.
But you will be doing it 100% on your own. The dealer won't even provide any guidance -- because they have none to offer, as dealers don't do this kind of work and aren't interested in it. A dealer service manager or parts desk guy will always tell you that installing X option on a car that didn't have it originally will not work, because if they told you it might work and then it didn't, who gets blamed?
The upshot is: by all means, take the time and trouble to install an auto AC system if you are dying to have it. But recognize that you'll have to do it yourself, and it will involve probably a substantial effort and not one for beginners.
There are easier lo-trim-to-hi-trim upgrades that anyone can do: simple bolt-ons like leather steering wheels, heated mirrors, or touchscreen stereo, or somewhat more advanced projects like headlight washers or heated seats. Rebuilding the dash and entire ventilation system is rather ambitious, and the folks who would be capable of it would not have "ask the dealer" as step one. Gotta walk before you can run.
Doing upgrades is fun, and doing them so that they are indistinguishable from "factory" is a great way to learn a lot about how your car is made. I encourage everyone to learn how to do this. But, for your own sanity (and bank balance), start with some smaller projects first to build those skills.
Replied by Motacilla on topic Manual AC to Auto Climate Control Mod
Last edit: 26 Dec 2024 09:00 by Motacilla.
The following user(s) said Thank You: nicka.k
Time to create page: 0.224 seconds
