Diagnosing power loss
07 Apr 2024 21:07 #255490 by Bennyb7
Hi again everyone,
I have a new issue I could use some help with. My 1996 ja22w (k6a) is loosing power after a few minutes of driving. Everything runs smoothly when it is first started, but after less than 5 minutes of running, I only have about 50 percent of my power, the turbo becomes quieter, the valves (or exhaust leak) become more audible. From my research, I'm thinking maybe o2 sensor or coil, but I have a very hard time finding parts so I'm hoping someone can help me with a sound diagnosis before I break out the wallet, or if anyone has experience with wiring a universal o2 sensor or universal coil?
open to any advice!
08 Apr 2024 03:23 #255494 by Lambert
Replied by Lambert on topic Diagnosing power loss
Have you checked the condition of your exhaust? If it's blocked in one of the catalytic converter then that will reduce power and make any leaking more obvious.
The following user(s) said Thank You: Bennyb7
08 Apr 2024 07:14 #255495 by Busta
Replied by Busta on topic Diagnosing power loss
Very hard to diagnose remotely. Check the valve clearances. Do a compression test. Check for boost leaks.
08 Apr 2024 10:32 #255497 by Bennyb7
Replied by Bennyb7 on topic Diagnosing power loss
I'll take a look at it while it's running. I've heard blocked cats get noticeably overheated.
08 Apr 2024 13:01 #255498 by Bennyb7
Thank you for the response! Are you willing to give me some details about how one goes about checking valve clearances?
08 Apr 2024 18:27 #255501 by Busta
Best to watch a few videos or find a good handbook that talks you through the process. It's not difficult, but it is a bit more involved than regular servicing.
In simple terms you remove the valve cover, rotate the engine to put each piston at top dead centre then measure the clearance between the cam lobes and the valve buckets.
