Re:Gen 4 "Smart" charging...
- Thank you received: 666
08 Mar 2024 09:47 #254903
by facade
Gen 4 "Smart" charging... was created by facade
So yesterday I had a flat battery (10.5V).
Now I hadn't used it whilst there was corrosive salt on the road, so it had probably been standing 3 to 4 weeks.
I dropped the charger onto it for half an hour and got it started easy enough, and according to my clampmeter, the starter took it overrange (199.9A), but it charged at 14A- for about 2 minutes, then dropped to 4A! which must be the smart charge kicking in as it warmed up.
No wonder the battery goes flat now I don't drive 2 hours a day, it would take 10 hours driving to charge it back up now.
I don't have anything on the smart charge system, so I don't know if this is because the battery is duff, or it is a "design feature" (which I'm inclined to believe)
Anyway, the battery has been on the accumate since yesterday, and seems to be charging fine, none of the cells are bubbling yet....
I almost pulled the trigger on a new one from Tayna @ £60 but if the old one is still fine it would be a waste of money to swap it now.
Looks like I'd best drop the Accumate on it every couple of weeks in future.
08 Mar 2024 11:08 #254904
Replied by mlines on topic Re:Gen 4 "Smart" charging...
As far as I am aware the smart charging does the opposite to what you have described seeing.
It prevents charging until the engine has warmed up in order to not overload the engine whilst the oil is thick. It's an emission thing
Sent from my ThinkPhone by motorola using Tapatalk
08 Mar 2024 12:03 #254910
by facade
Replied by facade on topic Re:Gen 4 "Smart" charging...
I'm fairly sure that it charges mainly whilst warming up- because emissions aren't measured during warm-up (officially "A cold battery is more efficient at accepting charge"- yeah, right
), and then cuts back.
Certainly the forums for The Other Car are full of "My stop start is flashing" - because stop-start is disabled as the battery runs down, which it does if you don't drive for several hours a week.
Is there anything in the manual about testing it, or it's operation?
I'd happily buy a new battery if the battery is not accepting a charge, but as it provides 200A plus to start it when virtually flat I can't see how that could be the case.
I know it is no end of trouble for Fords, and the fix is to pull the pwm lead out of the alternator, and then it reverts to proper operation.
Smart Charge is a bit of a grey area shrouded in mystery on t'interweb.
08 Mar 2024 13:59 #254915
Here is the description from the manual.
When looking further into it for a guy in Australia who had batteries continually dying I am sure we saw it back off at the start and only start properly charging when the blue temperature light went out.
08 Mar 2024 16:20 #254923
by facade
Thanks. Could you pull "Charging system specifications" please?
It doesn't read like what I know about Ford, their objective was to lower emissions, not to compensate for load, whereas this reads as if it increases output when there is a high electrical load.
Maybe it did charge a lot more when the blue light went out, I did my errands in it after I got it started, and it only took about 18 hours on the accumate, which is around 21AH, so either the battery is half capacity or it must have but a fair bit of charge in when driving.
I should have hung around measuring for longer yesterday, but it was bitterly cold here in the wind standing watching a meter.
08 Mar 2024 16:40 #254924
We had some readings from him somewhere as the car started and warmed up. I am sure his started up by not charging and then as the engine warmed switched to charging. This meant that if you only go 500 yrds to collect a newspaper everyday, the car goes flat eventually
The following user(s) said Thank You: facade
Time to create page: 0.189 seconds
