Re:Re:Cargo barrier
28 Nov 2023 19:24 #252435 by Ulltand
Cargo barrier was created by Ulltand
Hi there,
Im looking on a 2-seated Jimny gen 4 with cargo barrier steel net. Installed im a bit to tall for a nice driving position. However it looks that it could be fitted in position 20 cm back. But if soo how about det lower steel panel? My best
28 Nov 2023 20:54 #252440 by mlines
Replied by mlines on topic Re:Cargo barrier
I have made a video on exactly that
Sent from my ThinkPhone by motorola using Tapatalk
The following user(s) said Thank You: Ulltand
28 Nov 2023 20:56 #252441 by Pondboy
Replied by Pondboy on topic Re:Cargo barrier
I managed to move the upper cargo mesh back 100mm. Just loosened the lower fixing bolts on the solid section, bolted in the mesh with 100mm 6m stainless bolts and a nut to hold the mesh back against the bolt head. Located all four points on the mesh into the existing fixing points (two on the solid section), then tightened up the bottom nuts on the solid section, which is now at an angle. Didn't try to locate the mesh hooks onto the lower solid section, but nothing has rattled since I did the fix. Gave me about 7cm more rearward seat travel. I tried 120mm bolts, but the side bars narrow preventing a good fit.
Hope that this helps.
Gen4 LCV, PB
Sent from my IN2013 using Tapatalk
29 Nov 2023 10:32 - 29 Nov 2023 14:28 #252451 by Ulltand
Replied by Ulltand on topic Re:Cargo barrier
Thats a great video Martin, thanks! Would it also mean that you can position the seat backwards on the rail? Or just tiling it more? Need 10 cm additional legroom.
Edit. Tested the video approach and won plenty of legroom as vell. Well enough for my 190 cm. :)
Last edit: 29 Nov 2023 14:28 by Ulltand.
29 Nov 2023 12:21 #252461 by Pondboy
Replied by Pondboy on topic Re:Re:Cargo barrier
My setup
PB
29 Nov 2023 19:16 #252488 by Ulltand
Replied by Ulltand on topic Re:Re:Cargo barrier
Smart! But even my strongest specs cant compensate for the last pic. :) Guess that there is the same approach as the upper part?
Time to create page: 0.388 seconds
