Juddering after some work
20 Jul 2023 11:27 - 20 Jul 2023 11:34 #249918 by manyskills
Hi All,
Have just had kingpin done on driver's side, and new power steering belt. I don't know if it is just coincidence, but in this same week I am now experiencing a small but noticeable loss in power when accelerating, and have a judder when I'm in the lower gears (not on motorway).
I'm no mechanic, but the parts that have been changed don't seem like they would cause these symptoms?
I am waiting on a new IAC valve as I am having the "almost stalling at lights" issue. Will wait and see if this is contributing to it.
Spark plugs are less than 6 months old, and I don't rack up a lot of miles. I had to change one ignition coil a while back, and while the part numbers were the same, it isn't a perfect identical copy. If anyone has a link to a guaranteed match, I would love to know so I can rule that out too.
Any suggestions for things to check would be much appreciated!
Thanks!
Just editing to say. Gen 3, 2003, M13A, PS no AC.
Last edit: 20 Jul 2023 11:34 by manyskills. Reason: adding car info
20 Jul 2023 12:15 #249919 by Scimike
Replied by Scimike on topic Juddering after some work
Could be a coincidence, but then they also say the last thing you touched is probably the issue.
Juddering
Jack the front wheel that's had the kingpins changed and feel for any play. Also rotate the wheel to check all is smooth, no odd noises. Also check if any  balance weights have been knocked off the wheel, or swap them front/rear see if anything changes.
Powerloss
Is the Ac working in that the electric clutch on the Ac pulley engages/disengages when switched on off.
M
20 Jul 2023 13:15 #249921 by manyskills
Thanks.
No Aircon in mine, though, so won't be that.
I'll get it up and check the wheels.
You have reminded me though, I do need the tracking done which may explain the judder, but not the loss of power.
20 Jul 2023 13:18 #249923 by DrRobin
Replied by DrRobin on topic Juddering after some work
Is the judder a misfire or is coming from the wheels/drive train? Slip the clutch when rolling, coast and see if you can feel any judder.
If it only does it under power and feels like a misfire then might be a long shot, but did the vehicle stand for a while when the works were done? If it did it could be
- Battery very low
- Water in the fuel tank
- Brakes binding
Hope that helps
Robin
20 Jul 2023 14:44 #249925 by manyskills
Will make mental notes on my way home from work, but I first noticed the judder when accelerating. Like I said, not noticeable when on the motorway, more so in gears 1, 2, and 3.
I part work from home and don't go far on the weekends, so the car is often driven less than 10 miles a day 3 times a week, with the occaisional blast on the motorway to Liverpool. The kingpin + belt was changed friday evening (brother in law is my saviour mechanic), and driven home, but then left until tuesday.
I had a worry about the battery. Seeing a engine draw/rev drop when I connect my phone to the aftermarket stereo via bluetooth (which could also just be coincidence with the already dodgy IAC). I don't know the age of what's in there, but it isn't stock; it's a halfords one. I am wanting to put in an aux battery for camping etc, already installed the battery tray and have been told to consider a new battery when setting up the split charge system. Had this car over 12 months and never had a flat battery (touch wood).
Thanks for the advice. Will check everything suggested so far.
20 Jul 2023 15:11 #249926 by Scimike
Sorry about AC, did read it, but my mind swapped to AC belt as I typed. Possibly an age thing or the fact I was sitting in the hot sun as I typed wishing I had AC
The following user(s) said Thank You: manyskills
Time to create page: 0.200 seconds
