Gen 3: Replacement Seat & Seatbelt Anchor Bolts - what's the right size?
- GandHisJimny
- Premium Member
- Thank you received: 11
07 Jul 2023 15:56 #249778
by GandHisJimny
Jimmer II (2007 JLX+ auto in black & silver) : Android head unit, Black Raptor Steering Damper, Yokohama Geolandar G015s, rear cabin light, OEM wind deflectors
Gen 3: Replacement Seat & Seatbelt Anchor Bolts - what's the right size? was created by GandHisJimny
Hi all, I have my rear seats out at the moment getting the new boot fitted. It is a fresh OEM panel and crossmember so I was thinking I might as well replace the 18yo old bolts that are a bit cross-threaded and sad. I've done some searching but I'm still unsure on what the right size for a replacement is and indeed where is best to buy them.
Is there an OEM part number or anything like that to get original style ones?
This thread ( www.bigjimny.com/index.php/forum/6-jimny...elt-anchor-bolt-size ) suggests 7/16-20 UNF, which I suppose is the thread spec. What's the right length?
Thanks
Thanks
07 Jul 2023 17:21 - 07 Jul 2023 20:38 #249779
by fordem
Replied by fordem on topic Gen 3: Replacement Seat & Seatbelt Anchor Bolts - what's the right size?
I'm fairly certain it's a metric thread (7/16-20 UNF is imperial) and I would suggest OEM bolts in a new OEM panel - seat belt fasteners don't take a standard bolt, it's done deliberately to "dissuade" folks from fitting a "weaker substitute".
Last edit: 07 Jul 2023 20:38 by fordem. Reason: typo
- Thank you received: 1827
07 Jul 2023 19:02 #249780
Replied by Lambert on topic Gen 3: Replacement Seat & Seatbelt Anchor Bolts - what's the right size?
If memory serves its M12x1.25 or metric fine. Can't remember length exactly but something like 40 or 45mm but don't quote me on the length.
- Roger Fairclough
- Thank you received: 210
07 Jul 2023 20:56 #249781
by Roger Fairclough
Replied by Roger Fairclough on topic Gen 3: Replacement Seat & Seatbelt Anchor Bolts - what's the right size?
They are 11mm x1.25 and the spares I have have a fully threaded length of 26mm but this length will vary as to the distance piece that keeps the belt end bracket away from carpet or trim.
Roger
Roger
08 Jul 2023 06:20 - 08 Jul 2023 06:24 #249782
Replied by yakuza on topic Gen 3: Replacement Seat & Seatbelt Anchor Bolts - what's the right size?
Pretty sure it is 7/16 UNF, it is the same on most or all cars. Some could differ but suzuki don't.
Last edit: 08 Jul 2023 06:24 by yakuza.
- GandHisJimny
- Premium Member
10 Jul 2023 07:34 #249800
by GandHisJimny
Replied by GandHisJimny on topic Gen 3: Replacement Seat & Seatbelt Anchor Bolts - what's the right size?
Thanks for the replies all. Looking at my existing seatbelt anchor bolts - which I believe are stock (2005) - they have UNF written on the head so 7/16 UNF is mostly likely right. The seatbelt bolts don't say anything on them at all though so may be metric, hence the difference in answers(?).
Just found it odd given other aspects of the car are meticulously part numbered (e.g. every plastic trim clip) that there wasn't a bolt number.
Time to create page: 0.143 seconds
