Low power under load and exhaust blowing ...
  • madfishpaul
19 May 2022 09:18 #243360 by madfishpaul
Hi all,
I need to call on your collective wisdom, I have spent some time searching for existing treads but not found anything similar...  hopefully someone can help.
So,  I'd had the Jimny (1.3 16v) for a week, all working fine,  nice and tidy truck.
I'm on the motorway sitting between 60-70mph for about an hour, all good.  Come up behind a lorry,  put my foot down to overtake,  and then I get an exhaust blowing noise, and not much in the way of throttle response...
The problem has remained constant since then;
Revs fine out of gear.
1st is fine.
2nd a little exhaust noise and reduction in power.
3rd,  ok on the level, more noise, less power.
4h,  lots of noise, very little power.
5th - no chance unless you are going downhill.
Underload (uphill) is by far the worst. Local hills I would normally be in 4h going up happily at 50mph are struggling in 3rd,  need to drop do 2nd, 30mph max.  Load % reading on the OBD will not go past 40% in 3rd.
No EML.
Connected OBD - no fault codes.
Removed middle and rear exhaust (checking for blocked cat)- no change.
Changed exhaust manifold gasket - no change.
Changed spark plugs - no change.
Checked for inlet manifold gasket leaks (ran engine and sprayed brake cleaner) - no increase in revs.
Checked the MAS - doesn't appear to be one.
Next on my list was egr - but OBD reader reports this as all ok (reading through a previous thread it suggested if that's the case leave if alone), also,  why would this stick open when the engine was up to temperature?
Any help or advise would be welcome...
19 May 2022 13:08 #243366 by DrRobin
If I am doing 60-70 on a motorway and put my foot down I don't get much acceleration either, that is in a 2011. I don't however, get an exhaust blowing noise.
It looks like you might have a leak, but it only occurs at higher temperatures and higher load/revs.
When you mention about uphill was 50mph in fourth in this car or another car? I am in fourth in my Jimny with the foot flat to the boards when I would in top gear in another car.
Robin
  • madfishpaul
19 May 2022 14:26 #243368 by madfishpaul
Replied by madfishpaul on topic Low power under load and exhaust blowing ...
Hi Robin,
Unfortunately the comparisons are with this Jimny, and it is way way down on what it was (and it didn't have that much to start with !).
Just changed the coil packs - no change.
Going to be EGR this evening me thinks...
  • madfishpaul
20 May 2022 18:13 #243387 by madfishpaul
Not the
20 May 2022 18:33 #243388 by Scimike
This increase in noise that sounds like a blowing exhaust, still present?
That's a big step change that should be possible to find if it is a blowing exhaust. If not what can make blowing sound and not be the exhaust?
Maybe worth doing a compression test just in case it's leaking.
The following user(s) said Thank You: madfishpaul
22 May 2022 06:40 #243399 by yakuza
Sounds like when mine had a blocked cat or two.
Depending on market and year there is two cats, one in the manifold that often disintegrates and these pieces go into the next cat. Got two jimnys in my parking lot now, one with no cats, one with an aftermarket cat. Same with a friends jimny i met In Denmark 3 weeks ago.
Time to create page: 0.245 seconds
