4WD Flashing Light Diagnosis HELP
- Brazen1
31 Mar 2022 08:08 - 31 Mar 2022 08:09 #242612
by Brazen1
4WD Flashing Light Diagnosis HELP was created by Brazen1
Hi,
I've read EVERYTHING on this issue and tried every technique suggested on my 2012 Jimny without success. My mechanic is also pretty stumped.
- 4WD TC engages no problem.
- 4WD High and Low light flashes (slow tempo) after few seconds when engaging.
- Disengage works fine, as in, it reverts tback to normal (no lights) when 2D is selected.
- There's suction at all hoses @ the Auto Hubs. No leaks
- I've replaced the Vsv1 and Vsv2 Actuator Solenoid, check valve, filter and Pressure Switch. Replaced with genuine Suzuki parts from the dealer.
-my Jimny is an Auto. When I put her in Neutral, I can hear the hubs clicking particularly on one side continuously but the lights keeps flashing.
- We put it up on on hoist. Engaged 4WD. One side (right) locks in and rotates accordingly when in Drive as you accelerate. Left side rotates slow though and not as fast as the right. When we switched/swapped the hubs over, the same thing happens on the left - it doesn't rotate as fast as the right. So it's not one of the hubs.
- Sick of the problem being months in trying, I ordered new Manual Locking Hubs today. In anticipation for this, I blocked off the hoses underneath the car to fool the system into thinking its all sealed but error remains.
I don't know what else to do. Please help someone with the brains because I'm so done and feeling dumb.
I saw a YouTube video where someone did the manual hubs. He blocked the hose at the Manifold and he crossed a wire on a white connector under the battery. I tried that but I think it's the wrong connector maybe - I tried it on the two-wire connector bolted onto the vsv array. There's another white connector with 4 wires coming in which I tried to cross but this didn't work either.
PLEASE HELP I've been trying to fix this for 3 months Can't for 4 wheel driving! Ufff
Attachment not found
Last edit: 31 Mar 2022 08:09 by Brazen1.
- Thank you received: 1975
31 Mar 2022 08:47 #242615
Replied by Lambert on topic 4WD Flashing Light Diagnosis HELP
Ok so basics first with one wheel in the air and 4x4 selected that wheel should not rotate freely. Second, confirm that the vacuum pipes are going to the correct ports on the hub so that it's not unlocking one as it locks the other. Beyond that it's possible it's electrical which could be a pain to find.
31 Mar 2022 08:51 #242616
Also is the wiring at the transfer case intact?
- Brazen1
31 Mar 2022 10:46 #242622
by Brazen1
Replied by Brazen1 on topic 4WD Flashing Light Diagnosis HELP
The wheels are locked when off the ground and 4WD selected.
The hoses being wrongly routed doesn't explain the initial error but I'll take a look thank you.
- Brazen1
31 Mar 2022 10:52 #242624
by Brazen1
Yea we checked it and it looks OK all connected.
I'd like to know how to simulate having manual hubs by at least disconnecting/eliminating the vaccum system.
I tried blocking off the hoses to fool the 4WD Controller into thinking the hubs have locked but it didn't Work. But maybe I did it wrong.
How exactly is it done because blocking the tubes (they both pull vacuum ok to engage/disengage) didn't stop the lights flashing. As I wrote, I've replaced everything under the bonnet already.
Is there a connecter I need to short in order to finish that job? Please
31 Mar 2022 11:29 #242626
All I did with my manual hubs was plugged the hoses and it works just fine. The only feedback on the vacuum system is at the valves so if they are working correctly the system doesn't know that the pipes don't go to the hubs anymore. It's my understanding that the electrical bridging is not necessary on newer models including my old 2011 and current 2018.
Time to create page: 0.262 seconds
