Crankshaft Pully
- Brian
29 Nov 2010 14:41 #6760
by Brian
Crankshaft Pully was created by Brian
Hi all
Just had the crankshaft pully fall off my 2004 jimny mode.
Looks like the rubber has worn between the parts and then it seporated.
I have bodged it back together by drilling and screwing the 2 halfs together (got me home)
The question is can I weld the two pieces together or is there a need to have the rubber interface ?
Just trying to save the £145 for a new one.
Answers on a postcard please
Cheers
Brian
Cheers
Brian
29 Nov 2010 15:00 #6762
by facade
Replied by facade on topic Re: Crankshaft Pully
The 2 piece pulley forms part of a vibration damper. If you can weld it so it runs true, likely you won't notice any difference, or you could find an increase in noise and vibration at a particular speed.
I suppose something could break due to the extra vibration, eg the crankshaft or a mounting for the alternator or simillar
- Johnniehec
- Thank you received: 56
29 Nov 2010 15:45 #6765
by Johnniehec
Replied by Johnniehec on topic Re: Crankshaft Pully
Is the £145 from the "Main Stealers"?
Personally I'd try to get a replacement from a breaker, wouldn't consider welding.
cheers,
John.
cheers,
John.
- darthloachie
29 Nov 2010 15:59 #6767
by darthloachie
Replied by darthloachie on topic Re: Crankshaft Pully
try camsuzuki
see thread on here
see thread on here
- Brian
29 Nov 2010 16:40 #6772
by Brian
Replied by Brian on topic Re: Crankshaft Pully
Hi
Replacement is from local autoparts.
Havt emailed camsuzuki.
Thanks for the help
Brian
Thanks for the help
Brian
30 Nov 2010 20:31 #6850
by Millduu
Replied by Millduu on topic Re: Crankshaft Pully
Replaced one on my cousins P66POD a couple of months ago and I think it was around £125 from suzuki.
I'd avoid a second hand one as you might be buying the same problem.
His is a 2001 with 70,000 miles so you must be unlucky for a 2004 to fail so early.
