Tie rod ends/ tire swap -wobble back
06 Apr 2021 06:08 - 13 Apr 2021 16:36 #234273
Tie rod ends/ tire swap -wobble back was created by yakuza
last summer I shimmed my lower king pin bearings and checked lube and state of them shortly just before taking the car on a longer trip.
And most traces of any wobble I had at 75-80kmt (47~50mph) was gone.
So yesterday I changed the steering linkage rod ends. both balls out and in with brand new.
Much tighter of course as the old ones had alot of play in them.
But to my surprice, wobble is back!
Changed over from winter to summer wheels as well so just might have been unbalanced wheels, will rotate them when weather gets better.
Last edit: 13 Apr 2021 16:36 by yakuza.
06 Apr 2021 07:12 #234274
by Scimike
Replied by Scimike on topic Tie rod ends -wobble back
OK thats also on my did not expect that list!
Like you I would expect it to be the tyres, but am interested if you find this is not the case.
Is it possible the play in the old tie rod ends was insulating the steering from the "wobble" ? Not sure, let us know what you find when you rotate the tyres.
All the best
Mike
All the best
Mike
- Thank you received: 115
06 Apr 2021 11:16 #234275
by maverick
Jalapeño, IISY?
Replied by maverick on topic Tie rod ends -wobble back
When "wobble" appears, check:
Panhard Bushes
Steering Tie Rods Ends
Wheel Bearings
King Pin Bearings (i would not bother with shims)
Wheels Balanced
Wheel Alignment
Inner Wheels free of dirt/mud
Panhard Bushes
Wheel Bearings
Wheels Balanced
Wheel Alignment
Jalapeño, IISY?
- Thank you received: 673
06 Apr 2021 13:29 #234277
Replied by DrRobin on topic Tie rod ends -wobble back
Wheel alignment would be the obvious choice, since that will have changed in replacing the steering ball joints. After that, the most likely is anything you removed, so wheels not siting square or possibly swapped over between axles?
13 Apr 2021 16:27 - 13 Apr 2021 16:27 #234446
Replied by yakuza on topic Tie rod ends -wobble back
So now tried to swap the rear wheels to the front axle but still same wobble at around 80kmt that I did not have with the winter tires. Only thing swapped is the tie rod ends and now later the prop shaft to the rear axle.
My winter tires (also 235) got OZ alloys, all fine.
These are the original 2005 and later five spoke alloys (with BFG 235) that others too have reported having wheel alignment problems with. Some say the centers of the alloys are uneven and difficult to center in the wheel alignment machines.
Do anyone have a tip of how too align them properly?
there is also the possibility that when offroading with 0.4 bar "pressure" that the wheel spin in side the tire..? in wich case a simple alignment should fix it.
Last edit: 13 Apr 2021 16:27 by yakuza.
13 Apr 2021 17:32 #234450
Replied by Riccy on topic Tie rod ends -wobble back
Wheel balancing is the problem here. I would try putting your winter wheels back on if they were ok and see first if that improves the issue.
Then look at the tyres on the summer wheels. They have been sat for a while and may have suffered. their balance weight might have changed too.
I find balance beads, ceramic for preference, are the best way with big tires and can allow for mud or stones stuck in the treads very well too. Maybe they are worth a try?
Time to create page: 0.239 seconds
