Re:Re:Rear view camera gen4 install
- lookonimages
- Thank you received: 65
Watch Martin's install video and got some sort of manual from internet.
Everything work and is really a plug and play option. Seems radio is already setup to know when you put vehicle in reverse to switch over to the radio display to show camera display the moment you put jimny in reverse.
The SA version wiring seem to be a little different to the bigjimny video of Miles install. Sa version is plug and play and everything is already in that thicker black wire rubber protection piping. You plug in camera and everything is done for you right to the back of the radio. Even the green wire socket has already been added to circuit wire from the back. it is just that little green one that goes into the back of infotainment/radio system and another red wire that need to be attached to the some specific wire at the back of radio.
This red wire turn on the camera itself when you add power to it. the red wire is about a foot from the green socket that goes into the back of the radio.
Current red wire is attached to ACC fuse via piggyback connection. So when ignition on the camera switch on and when you put in reverse the radio display auto switch over to camera display on radio itself. The BAD of this camera is ON all the time that ignition is on.
I would have liked to connect the single red (that power the camera) to be linked to a "reverse light wire" right there by the dashboard at the back of the radio.
Then the camera is only switched on when you put the car in reverse and same time the radio switch over the display to the camera display. Then camera is on for very short periods that make me think it is better for camera instead of having it on all the time while ignition is on.
There must be a wire right there at instrument radio panel to enable tapping into the reverse light wire there, (why else have it been put that little red wire there).
Where did you guys attached the red wire (behind the radio) to get power for the camera.
I know I can pul in another wire all the way from the reverse light BUT I am sure there must be a reverse light wire availble already very close to the back of the radio, from where i can tap power.
Tried to look for such a wire maybe with a label saying it is reverse light wire but I cant find one.
Any ideas before i bring an extra cable all the way through to the front for reverse light power.
- GeorgeC
- Visitor
This may help in finding the correct set of instructions for it as I have two sets here but need the part number to identify if it is the same.
- lookonimages
This is the only info on the box.GeorgeC wrote: Do you have the Part Number of the kit and exactly where (web page) you purchased it.
T196
9900L-78R00-CAM
Global Suzuki is 99195-78RA0-000
A number of countries have not taken the Global kit, they have sourced a local one (Australia for example). They probablymake more margin on a local purchased product.
Does it have the reversing guide lines on the screen?
- lookonimages
Yes sir it do have lines.mlines wrote: So thats a local market kit, not the Global Suzuki kit.
Sorry it has not yet installed. But i tested wiring before i install permanently and removing bumper. Just want to make sure all is working before doing the install.
This is what it look like.
