M16A swap which is better
- sealine150
26 Apr 2020 23:32 #221549
by sealine150
M16A swap which is better was created by sealine150
Hi from Greece. I have a 2009 Jimny m13 with vvt.
I am looking for a m16 swap.
There are 2 options.
M16 vvt from sx4
M16 vvt from swift sport
The first has more torque and the second more horsepower.
Which is better for a jimny with 235s tires stock gear and also daily driven??
M16 vvt from sx4
27 Apr 2020 06:08 #221550
Replied by Riccy on topic M16A swap which is better
Both will be the same when fitted into a Jimny.
The differences in power/torque are down to the inlet/exhaust setup and the ECU.
You need to be wary of swift engine from 2010 onwards as the crank trigger changed design and wont work after that year with a Jimny ECU.
The following user(s) said Thank You: sealine150
27 Apr 2020 07:26 #221554
by sniper
Replied by sniper on topic M16A swap which is better
No mechanical difference between the engines, as Riccy says it's all down to induction/exhaust and the "map".
The Swift sport 05-09 (Denso ECU) which you are considering has 123bhp, that was increased to 134bhp with changes to those components in the 2010 (Bosch ECU) model.
When fitted to the 1.3 induction system in the Jimny, I think they are quite heavily restricted. I have driven a few now and I would be surprised to see much over the 100bhp mark. They are a definite improvement and I want to do one myself in the future, but I think they don't reach their potential when installed as a 1.3.
170-180bhp is seen from the same engine with just cams and the correct fuel / exhaust set up. Lightweight and powerful, a good engine, if you have the money to extract the power from it......
sniper
sniper
- sealine150
27 Apr 2020 07:32 #221555
by sealine150
Replied by sealine150 on topic M16A swap which is better
There is a way for remap the M13 Ecu with M16 ecu maps and works fine.
So i think that the ecu problem will be solved with that one. the other thing is Swift engine is rarer than SX4. and much cheaper.
- CharterBoat
21 Jan 2022 23:29 #241385
by CharterBoat
Replied by CharterBoat on topic M16A swap which is better
Hey Mate, if your still able to answer this muchly appreciated what about post 2010 m16a engine from different cars like a 2013 s-cross, would there still need a different ecu?
- Thank you received: 1984
22 Jan 2022 02:46 #241388
Replied by Lambert on topic M16A swap which is better
The cam trigger wheel is different from 2010 onwards so the Jimny ecu can't run the engine.
The following user(s) said Thank You: CharterBoat
Time to create page: 0.182 seconds
