Re:Oil leaking on offside rear brakes
  • Jezza
08 Oct 2019 09:49 #214462 by Jezza
Oil leaking on offside rear brakes was created by Jezza
My first post, so Hi to everyone, and thanks in advance for any advice.
My wife's 2007 jimny auto failed last years MOT due to oil leaking on the offside rear brakes. My mechanic replaced the seal where the drive shaft meets the diff, and all was well. About 6 months ago we had two new rear tyres fitted, and it was pointed out to us that, again, oil was leaking over the same offside rear brake. So the same seal was replaced along with the rear brakes.
Had an MOT yesterday, and got the same problem again. Brakes were cleaned and got through the MOT.
My mechanic is a good guy, but he will admit he's not had much experience with Jimnys, working mainly on VAG vehicles.
Is this a common problem on Jimnys, and is there something we're missing? Many thanks for any help from someone who's had the same problem.
08 Oct 2019 09:52 #214463 by mlines
Change the bearing, the seal is a side effect
  • Jezza
08 Oct 2019 10:12 #214464 by Jezza
Replied by Jezza on topic Re:Oil leaking on offside rear brakes
Many thanks for such a speedy reply. Can I buy the bearing on Big jimny? Or does anyone know the part number? Many thanks
  • mickt
08 Oct 2019 13:52 #214474 by mickt
Replied by mickt on topic Re:Oil leaking on offside rear brakes
If you click on the Jimny Shop title in this forum you will see what is available. Just looked and they do list a kit for the rear wheel bearing at £65 but it is listed as nil stock. Drop mlines a message and he will help if he can.
  • Jezza
08 Oct 2019 14:22 #214476 by Jezza
Many thanks mickt, I'll have a look but this k I need a rear axle bearing kit. Thanks again
  • mickt
08 Oct 2019 15:21 #214479 by mickt
Ebay item # 251727136139 worth a look.
Time to create page: 0.572 seconds
