Re:Review of Autool OBD2 Reader / Display
- Thank you received: 923
21 May 2018 15:19 - 21 May 2018 15:50 #192845
Review of Autool OBD2 Reader / Display was created by X8GGY
I recently spotted these little gadgets mentioned on another thread in this fine forum, and thought I'd get one...These are little "heads up" displays that read data live from the OBD2 diagnostic port located under the dashboard (photo further down), a lot seem to beam the data onto the inside of the glass of the windscreem, but I wanted one that was a bit more robust and easier to read, so a colour screen facing me... The Autool one I spotted also featured an adjustable speed correction which is fantastic for a Jimny with bigger tyres fitted!
So it arrived -
In some very smart black boxes with an instruction book...
The OBD2 connector is just under the driver's left knee (on a UK model)
The plug just, errr, plugs in...
And the little device springs into life using power from the OBD2 plug, so no other power connectors or batteries are needed.
With the Jimny resting on the drive, 0 km/h*, 32 degrees ambient water temperature in the radiator and 11.7V coming out of the battery with the engine not running...
* this is easy to set to mph in the menus
Engine now running, the water temperature rises a bit and the voltage rises to 14V with the engine running and the alternator prviding more power to the battery(s). 912 is the RPM as I shifted the screen display from road speed...
Not a great photo, but this is the error code reader section of the software (no codes present
I had a run out and logged the speed against my iPhone running a GPS speedometer and changed the speed in the software to display at 104% which seemed about right
It was interesting to note that the speed from the OBD2 data port was different to that shown on the actual speedometer in the dashboard?! Although in the photo below it does read similar...
When driving the RPMs are show as a coloured bar across the bottom under the speed, the idea being to show you when to shift gear (this is also settable in the menus as an audible alarm)
A great little gadget then! It now shows a more accurate speed representation, water temperature that means something rather than looking at the gauge and thinking "it looks a bit warm"? LOL, and a nice readout of the actual voltage being produced / from the battery at rest...
It's possible to change the screen to show lots more options of data, and to set speed, revs and water temperature alarms, etc... And as said above to even read and reset error codes from the ECU, so well worth the small cost of one of these, or similar, little gadgets!
So it arrived -
Last edit: 21 May 2018 15:50 by X8GGY.
- mickt
21 May 2018 19:36 #192847
by mickt
Replied by mickt on topic Review of Autool OBD2 Reader / Display
How much was it? And does the obd2 port live there on all models as mine is a 2001?
21 May 2018 20:01 #192848
Replied by X8GGY on topic Review of Autool OBD2 Reader / Display
I paid a bit over the top at £39~ but it was from a UK seller and was delivered quickly... they are available cheaper...
Hmmm, I don't know when the change to OBD2 was made... someone more knowledgeable will be along soon
Where's Rhinoman when you need him
21 May 2018 20:51 #192849
Old thread on the OBD2 question -
www.bigjimny.com/forum/6-jimny-chat/4443...have-obd2-ports.html
The port looks like a scart TV socket.
- MadsV
21 May 2018 21:56 #192850
by MadsV
Replied by MadsV on topic Re:Review of Autool OBD2 Reader / Display
Nice. But are there any readings of oil temperature or pressure?
22 May 2018 05:42 #192855
The car just have the on/off oil pressure sensor (I think) and analogue water temp sensor.
Replied by yakuza on topic Re:Review of Autool OBD2 Reader / Display
I do not think there is such info in the cars system. I haven't seen it available and i do not think there is analogue sensors to provide it.MadsV wrote: Nice. But are there any readings of oil temperature or pressure?
Time to create page: 0.393 seconds
