Separating Jimny body from frame
08 Apr 2018 09:30 - 08 Apr 2018 09:31 #191442 by Bosanek
In order to sort out a severe underbody rusting of a Jimny, it was recommended to first dismantle the vehicle (to completely separate the body from the frame).
The thing is that the lot of the rear floor area (under the seats, bottom of the boot etc.) is eaten away, and the chassis rails, mounts, panhard rods etc. are severely rusted too.
So, my question is - has anyone separated Jimny's body from the frame (dismantled the vehicle) and how complicated is it?
Is the wiring a major issue? Which items have to be dismantled first in order to remove the body - like the headlights, wirings, gearbox stick, center console and instrument panel items, ventilation pipes, etc.??
Last edit: 08 Apr 2018 09:31 by Bosanek. Reason: Typo
08 Apr 2018 20:25 #191462 by kirkynut
I've never seen it documented anywhere but imagine if you spent enough time looking at it and figuring out a plan of action, making a list as you go, you'd be ok.
It's a case of thinking it through, so things like if you undo the plugs on the back of the lights, will that be enough? Follow the route of wires and brake pipes to figure out a plan of action.
08 Apr 2018 20:41 #191464 by kirkynut
This guy's done it, perhaps contact him:
www.bigjimny.com/index.php/forum/8-my-ji...k-green-jimny#190974
09 Apr 2018 19:17 #191489 by Bosanek
Thank you very much for this link. I contacted the guy and I am waiting for his response.
Well it appears that this is a rather tedious endeavor. Not complicated per se, but a lof of things have to be taken care of, and a lot of things can become an issue (seized bolts, corroded brake lines, etc. ...).
A few mechanics told me that it would take approx 30-60 man-hours just to dismantle the vehicle (without touching the interior console and without dismantling the engine). The amount of time depends on the condition of the bolts and on who does it.
According to them, it takes at least 60-90 man-hours to put it all back.
Well there it goes ...
09 Apr 2018 21:20 - 09 Apr 2018 21:20 #191497 by kirkynut
You've got to really want to do it. I've taken a monocoque car down to a bare shell effectively twice in one go when I re-shelled and re-built a Vauxhall Nova GTE (Corsa A) with a younger base model shell.
It can't be any different to get to the being ready to pull the shell off the chassis stage. It took me a few months of a day here and there on rest days with part days.
Last edit: 09 Apr 2018 21:20 by kirkynut.
13 Apr 2018 09:22 #191654 by spin4pike
it's not that hard! In 5 hours alone I was able to dismantle all the components.
it took 6 people to lift the body.
I will come back with detailed specifications in no time
Trimis de pe al meu SM-G930F folosind Tapatalk
