clutch bearing noise?
  • rexthecat
21 Mar 2018 22:02 #190703 by rexthecat
clutch bearing noise? was created by rexthecat
Got this 'click click click' noise, sounds like a bolt catching something as it rotates. Starts at about 20 mph and only when accelerating, not in over run or when the clutch is down. Does that sound like a clutch bearing?
  • Jimx5
21 Mar 2018 22:19 #190704 by Jimx5
Replied by Jimx5 on topic clutch bearing noise?
The usual sound of a dry/failing clutch bearing is a constant metallic sound as the car is in neutral with the clutch pedal not depressed, the noise goes away when the pedal is pressed and the bearing has a load on it.
As i said this is the usual sound, sorry i can't be of more assistance.
You may need to get under the car and man handle the prop shafts and feel for worn universal joints.
  • rexthecat
21 Mar 2018 22:33 #190706 by rexthecat
Replied by rexthecat on topic clutch bearing noise?
cheers, yup strange one, not a worn uj or anything on the props, not the cvs or brakes far as I can see / tell / test The way the noise starts up at speed and and only under acceleration made me think clutch. Ill have another look, maybe I missed something....probably!
  • Jimx5
21 Mar 2018 22:43 #190707 by Jimx5
Hmm, you've got me intrigued, does the clicking increase with engine speed or road speed, i know you said under acceleration but is it in any particular gear?
21 Mar 2018 23:14 #190709 by Max Headroom
Replied by Max Headroom on topic clutch bearing noise?
Check your tyres; I had a similar thing (not on a Jimny) and it turned out to be a large stone stuck in the tread of a tyre, but I could nevertheless hear it from inside the car!
Worse case scenario could be something like a bolt that's embedded in a tyre.
Just a thought....
21 Mar 2018 23:41 #190712 by KJS
Replied by KJS on topic clutch bearing noise?
Just maybe a broken misshaped finger on the pressure plate, this is where the release bearing touches onto the pressure plate to release the centre disc!
Time to create page: 0.531 seconds
