13500lbs winch - max size battery to fit tray?
22 Apr 2017 18:07 #180488
13500lbs winch - max size battery to fit tray? was created by Riccy
Hi All,
Im fitting in a 13500bs winchmax winch on the jimnbits tray. Im going to put the solenoid box up out of the way and make a bracket for it. The question is what battery should i use?
Its mainly as a backup and rescue option for other vehicles, so wont be under enough stress to justify a second battery setup (yet). The handbook for the winch says a minimum of 650 CCA for the battery, so is there one that size, or preferably higher that will fit the jim with a standard 1.3 altenator?
Thanks,
Riccy
Thanks,
Riccy
23 Apr 2017 17:08 #180508
Replied by Riccy on topic 13500lbs winch - max size battery to fit tray?
Nice sunny day so ive been at it with the spanners (and grinder) again...
Decided to put the number plate on the lower steel bumper. I now need to make a new lower bumper, but might think about making a new one that fits better and has space for the plate.
The hook on the winch is too big to fit into the jimnybits towing eyes so ive clamped it onto the original tow point underneath for now. I bought some D shackles, but they are either too small or way to big. Be handy for the tree strap or snatch block i suppose. Ive decided to put the cover on it when its parked up to keep prying eyes off it
Its wired up and working (with isolator switch). The battery thats in it says 400a, but i cant see a CCA figure on it.
- TomDK
23 Apr 2017 18:14 #180510
by TomDK
Replied by TomDK on topic 13500lbs winch - max size battery to fit tray?
Then it a 400 CCA battery. It's not like it's a 400 Ah capacity battery.
About size of battery for your winch. It's just a matter of finding the best battery for the budget. I like Varta AGM batteries
Should be possible to find one that fits.
- 1066Boy
23 Apr 2017 18:50 #180512
by 1066Boy
Replied by 1066Boy on topic 13500lbs winch - max size battery to fit tray?
You could always use one of the sticker type number plates and put it on the bonnet just above the front vents.
23 Apr 2017 19:15 #180514
Replied by Daniel30 on topic 13500lbs winch - max size battery to fit tray?
lovely job Riccy
24 Apr 2017 05:36 #180517
Ah, i see - you would think i would know, being an electrician!
Will measure up and have a search for varta AGM then
TomDK wrote: Then it a 400 CCA battery. It's not like it's a 400 Ah capacity battery.
About size of battery for your winch. It's just a matter of finding the best battery for the budget. I like Varta AGM batteriesShould be possible to find one that fits.
Time to create page: 0.727 seconds
