Tyre noise or something else?
10 Nov 2016 10:27 #174460
by minibbb
Tyre noise or something else? was created by minibbb
My jim is on 215/75/15 BFG MUD Terrains which haven't got a huge amount of mileage on them. In the last couple of months the front offside tyre has got seriously noisy- before this they were all very quiet.
Pressure is fine, no damage to see and no whee wobble suggesting the wheel is buckled etc. Just a loud thump thump noise- increases more with speed.
I popped it to the garage as it had been suggested the whee bearing was the culprit but he seemed to think it was ok- not v noisy when you spin the wheel and no wobble noted.
Any other suggestions as to what it can be?
10 Nov 2016 11:42 #174462
Replied by yakuza on topic Tyre noise or something else?
vacuum free wheel hub not disengaging?
lubrication missing from inside hub/drive shaft?
(rethreaded) tyre coming loose from the stem of the tyre?
I do remember a school teacher when i grew up in the eighties who had similar trouble with his beetle.
Some of us kids had put pebbles inside the hub caps
The following user(s) said Thank You: minibbb
10 Nov 2016 11:47 #174463
by minibbb
Replied by minibbb on topic Re:Tyre noise or something else?
Thanks matey- it's on manual hubs. Not sure you mean about the tyre coming loose from the stem of the tyre?
I'll try and swap the spare with the wheel later and see if that helps
10 Nov 2016 11:58 #174464
Replied by yakuza on topic Re:Tyre noise or something else?
Sorry for language problems (I am Norwegian
The mould of the tyre can sometimes come loose from the stem of the tyre. The tyre can delaminate so to say.. not sure if offroading with low pressure can increase the risk of this happening, but i have had the problem myself with firestone mud tyres some 20 years ago. The dealer said it happens more often with remoulds.
balancing problems can be caused by this .
10 Nov 2016 12:37 #174465
by minibbb
Ah that's handy thanks- will try swapping the wheels and see if that helps
11 Nov 2016 17:57 #174516
by minibbb
So the wheel swap has cured the noise!!
Question is what on earth could be wrong with the tyre? It looks fine- no visual damage other than slightly perished near the bead. Nothing stuck in it etc
