Changing the antifreeze/coolant
- Graphite675
12 Nov 2015 17:18 #156118
by Graphite675
Changing the antifreeze/coolant was created by Graphite675
Hi Guys,
Just a bit of advice please.
To change the antifreeze/coolant, is it just a case of taking out the drain plug at the bottom of the radiator??
If so does the drain plug require a new washer or anything before screwing back in??
Cheers.
Cheers.
- jim
12 Nov 2015 17:50 #156120
by jim
Replied by jim on topic Changing the antifreeze/coolant
Just popped my head under and had a look at mine the plug is twist open by hand on passenger side. I don't think you need to replace anything just do it up tight.
Remember to flush the system well especially if you change to different type of coolant.
Which type of coolant will you be using?
12 Nov 2015 18:20 - 12 Nov 2015 18:22 #156124
by facade
Replied by facade on topic Changing the antifreeze/coolant
The radiator drain only drains the radiator. Most of the water stays in the engine block and the heater.
However, The Manual says to drain it here, top up again, leave the rad cap off and run the engine until the top hose gets hot (thermostat open) then drain again, and repeat until the water is clear.
This avoids nasty airlocks in the heater.
Then you empty out the expansion bottle, tip the required amount of neat antifreeze into the radiator and fill with water, (I usually squeeze & release the hoses a few times to get air out) run the engine (rad cap off) until the thermostat opens, whilst adding water to keep it full, then pop the rad cap back on, and half fill the expansion bottle with antifreeze mixture.
Run until the temperature gauge comes up, then switch off, and when cold, fill the radiator right to the top, fill expansion bottle to the line, and check the level in the bottle when the engine is cold a few times over the next couple of days.
Don't ever take the radiator cap off when the engine is hot - you can leave it off from cold and then run the engine.
Last edit: 12 Nov 2015 18:22 by facade.
The following user(s) said Thank You: jim
- jim
12 Nov 2015 18:33 #156126
by jim
- Graphite675
12 Nov 2015 18:46 #156130
by Graphite675
Replied by Graphite675 on topic Changing the antifreeze/coolant
Any suggestions as to which antifreeze/coolant to use?? I was planning on getting something from Halfords.
Cheers
Cheers
- jim
12 Nov 2015 18:55 #156133
by jim
The halfords spec charts at the coolant section advised Halfords OAT (organic acid technology) red silicate free coolant for Jimmy.
www.halfords.com/motoring/engine-oils-fl...-antifreeze-5-litres
Time to create page: 6.192 seconds
