Re:Tow bar wiring
- Sungaets
12 Apr 2015 11:41 #142335
by Sungaets
Tow bar wiring was created by Sungaets
Dean Shetland.
Can some one help, i am trying to wire up a tow bar socket to my 2014 jimny, i am finding it impossible to get it wired up, so far i have indicators, and brake lights, but i have come unstuck with the side lights and fog lamp, i have taken the trim out of the near side, i have also down loaded the tow bar instructions from the forum.What clour of wire do i require for the side lights and what colour for the fog lamp, i found one thread that said connect the fog lamp wire into the green black , i have no green black, the wire going going into the lamp is blue green, totally stuck some help would be very much appreciated.
Regards Dean.
Regards Dean.
- wombat
12 Apr 2015 11:53 #142336
by wombat
Replied by wombat on topic Tow bar wiring
Hi Dean, turn the foglamp on, use a circuit tester to determine which is the live feed then connect the wire to that one.
Connect the sidelamps using the same procedure and all should be well.
Cheers Ian
Cheers Ian
- Sungaets
12 Apr 2015 12:41 #142341
by Sungaets
Replied by Sungaets on topic Tow bar wiring
Thanks Wombat , i hadn't thought about using a meter, but to get the fog lamp switch to work don't i need to at least put on the side lights, if so how do i then determine what wire is powering what, as far as i can figure out the red yellow wire is sidelights , the tow bar socket should have a black and a brown, when i connect the black i get side lights on the trailler but only the left one at the rear works, if i connect the brown all iights come including indicators which makes me think i have an earth problem, i am unsure also what colour the earth wire is,is it black or black with white dotting?
Can anyone please help i am going bonkers .There doesn't seem to be a defined diagram for my car ,which is 2014.
Thanks in advance Dean.
- wombat
12 Apr 2015 12:52 #142342
by wombat
switch the sidelamps and foglamp on then check the feed at the actual lamps, this will tell you which colour wire feeds what, then connect that colour wire to the relevant socket wire.Also i usually connect the towbar socket earth wire to its own earth on the car body. Is the towbar socket wired up properly?
Ian
Ian
12 Apr 2015 14:23 - 12 Apr 2015 15:30 #142346
by Halford
I never wired my fog up as its on the rear right only (in UK anyway) so you'd need to maybe run a wire over to the right hand side ?
Replied by Halford on topic Tow bar wiring
Last edit: 12 Apr 2015 15:30 by Halford.
- markyp2000
12 Apr 2015 16:29 #142348
by markyp2000
Replied by markyp2000 on topic Tow bar wiring
Well to start with side lights are in the bumper and fog light is on the body so you only need to run 1 wire to the fog light the rest can be wires in behind the bumper
Time to create page: 1.516 seconds
