winch solenoids
  • markyp2000
31 Mar 2013 13:12 - 31 Mar 2013 13:42 #67403 by markyp2000
winch solenoids was created by markyp2000
Ebay number 121081508311 can any one tell me if this does in and out for the winch or do i need 2 of them as i have 2 in my box already and thay have packed up also my winch only has 2 wires going to it iv seen a few with 3 wires if that makes a difference
Last edit: 31 Mar 2013 13:42 by markyp2000.
  • vitara_mad
31 Mar 2013 14:40 #67407 by vitara_mad
Replied by vitara_mad on topic winch solenoids
No eBay APP ID and/or Cert ID defined in Kunena configurationyou would need 2 of them they are the old type of solenoids you better off getting a albright type its a sealed unit & all in 1
  • TomDK
31 Mar 2013 15:19 #67413 by TomDK
Replied by TomDK on topic winch solenoids
Agree with vitara_mad.
Get genuine Albright, or Albright-style TDS solenoid. Goodwinch sells both.
31 Mar 2013 16:05 #67417 by kirkynut
Replied by kirkynut on topic winch solenoids
My winch motor is like most and has 4 wires, 3 on top and the earth underneath. I would only use a proper albright too. I got mine from Devon 4x4.
  • markyp2000
31 Mar 2013 16:55 #67423 by markyp2000
Replied by markyp2000 on topic winch solenoids
thanks for the info ill order one thanks
  • gus2000
31 Mar 2013 17:58 #67434 by gus2000
Replied by gus2000 on topic winch solenoids
There are two main types of winch motors.
One with the stator (field) coil winding. This has four terminals. 2 for the field and other two for the brushes of rotor (armature). One wire of the brushes of armature is ground.
Another connection for the winch with stator permanent magnets, this has only 2 wires connected to the rotor brushes.
Integrated winch solenoids are different for each model of the motor
