sj steels on jimny
  • med
18 Mar 2013 09:09 #66161 by med
sj steels on jimny was created by med
i picked up a set of what i believe are sj steel wheels at the weekend (sort of star center)
do i need different nuts to the ones from my standard jimny alloys?
do sj steels have a lower offset than stardard jimny allloys?
any help appriciated
  • med
19 Mar 2013 22:11 #66337 by med
Replied by med on topic sj steels on jimny
Anyone?
  • darthloachie
20 Mar 2013 13:55 #66386 by darthloachie
Replied by darthloachie on topic sj steels on jimny
ideally you need wheel nuts for steel wheels
bits4vits stock them
don't know about the offset difference- there should be size markings somewhere on the wheel that may tell you what the offset is
  • med
20 Mar 2013 14:34 #66389 by med
the ones on bits4vits look like tapered ones?
im sure the wheels look like they should have radius nuts? i could be wrong?
tom
21 Mar 2013 22:26 #66494 by kirkynut
Replied by kirkynut on topic sj steels on jimny
The SJ steels need standard Jimny steel wheel nuts. They are tapered. I can't get to the bottom of if the alloy wheel nuts on Jimnys are the same as the steel wheel nuts or not but if they differ It's the angle of the taper that differs.
  • markyp2000
21 Mar 2013 22:35 #66497 by markyp2000
Replied by markyp2000 on topic sj steels on jimny
You cant use alloy wheel wheel nuts on steels the taper is different between then
Contact cam suzuki i bet thay got lots and lots of nuts for steel whels
Time to create page: 0.144 seconds
