Tappets/blown exhaust - HELP!
- discotroll
- Visitor
07 Feb 2013 08:46 - 07 Feb 2013 13:04 #61269
by discotroll
Tappets/blown exhaust - HELP! was created by discotroll
Hi everyone -
Need some quick help!
On the way to work this morning my 02 started to make a loud tappet/blown exhaust noise. The noise increases when I accellarate and I can hear it when I'm sat in traffic but cruising or slowing down it isn't there. Power is no lower than normal and engine is running smoothly as ever (i.e. it does splutter or struggle on tick-over).
As I come to work in the dark and wont be able to look at things till home in the dark tonight I could do with some pointers in the meantime...
Many thanks,
DT.
UPDATE - noise appears to be coming from the manifold side, towards the back of the block - quite a metallic sound.....
Many thanks,
DT.
Last edit: 07 Feb 2013 13:04 by discotroll.
- Dave cc
- Visitor
07 Feb 2013 13:12 #61285
by Dave cc
Replied by Dave cc on topic Tappets/blown exhaust - HELP!
Sounds like the manifold gasket has blown out can sound fairly harsh if its blowing that close to the block.
Also would check also that there is oil getting up to the head has the car been regualy serviced with frequent oil changes ? have seen 2 lately with camshaft/head faliure due to oil starvation.
What engine has your car got G or M series ?
- discotroll
- Visitor
07 Feb 2013 13:21 #61288
by discotroll
Replied by discotroll on topic Tappets/blown exhaust - HELP!
Hi -
Engine is the older cam-belt style of engine (SOC?) - not sure if these have hydraulic tappets or not (??)...
So far I've only beem able to do a quick inspection so can only go as far as no oil pressure light and there is plenty of oil in the sump - car has been well serviced throughout its life. I got to start it up just now at work and despite sounding like a bag of nails it's running really smoothly....
- Dave cc
- Visitor
07 Feb 2013 16:17 #61303
by Dave cc
Sounds like just a manifold blow whip it off stick some new gaskets on see what happens dont sound major
- Dave cc
- Visitor
07 Feb 2013 16:19 #61305
by Dave cc
Sorry forgot to say there are no hydraulic tappets on that engine the lash adjusters are manual
- markyp2000
- Visitor
07 Feb 2013 18:00 #61322
by markyp2000
Replied by markyp2000 on topic Tappets/blown exhaust - HELP!
Easy way to pin point an exhaust blow is get some hose pipe about an arms lenth put one end on your ear and move the other end around the joints and then you can hear the blow
Time to create page: 0.141 seconds
