Boot light!
  • J-Bro
28 Jan 2013 20:28 #60037 by J-Bro
Boot light! was created by J-Bro
Okay your stood facing your back door (open) on the left hand side above the back window there is an indent is it for a light?
I know there basically isn't a boot but wouldn't mind a light in the back that looks good!
Wiring diagrams? Or any ideas be cool!
Thanks
  • markyp2000
28 Jan 2013 20:39 #60041 by markyp2000
Replied by markyp2000 on topic Boot light!
On the lower left side there is a black bung you can put adoor switch in there and run a wire with a fuse to a light and the the earth side to the switch but you would need to put a 5mm sticky pad on the boot door
  • Skinhead
29 Jan 2013 00:16 #60086 by Skinhead
Replied by Skinhead on topic Boot light!
Ive just orderd a surface mounted reverse light and a door switch this morning to put in the back of mine. Live wire straight from the battery to the light, then a wire from the light to the door switch which will be earthed, job done, could be quite bright with a 21 watt bulb though!
  • gus2000
29 Jan 2013 01:49 #60089 by gus2000
Replied by gus2000 on topic Boot light!
k44rll wrote: My JB23W has this light as standard in XC spec...
Not sure if these parts are on the Suzuki UK system but here are the part numbers...
36210-74F02-6GS Lamp assy, rear room (gray)
36820-81A10 Wire Harness
03141-0520A Screw x 2
37670-79E00 Switch assy,trunk
Karl
Karl: Thank you for the information so interesting
Sincerely
Gustavo
  • Sponnie
29 Jan 2013 07:53 #60091 by Sponnie
Replied by Sponnie on topic Boot light!
Skinhead wrote: Ive just orderd a surface mounted reverse light and a door switch this morning to put in the back of mine. Live wire straight from the battery to the light, then a wire from the light to the door switch which will be earthed, job done, could be quite bright with a 21 watt bulb though!
What is it you have ordered? any pics of the unit?
I need something to light up the 'boot'.
  • Skinhead
29 Jan 2013 08:17 #60093 by Skinhead
I only orderd it yesterday of ebay, its just one of them surface mounted reverse lights, think they are for trailers, then a door switch off a bmw (cus they were cheapest on ebay an looks like it will fit) dont do anything yet, ill let you know what its like when its up an running :)
Time to create page: 0.219 seconds
