temp rises:-D
- suzuki jimny fella
22 Dec 2012 14:36 #55978
by suzuki jimny fella
temp rises:-D was created by suzuki jimny fella
My temp rises when out playing what can this be guy ok on road
- reaper
22 Dec 2012 14:39 #55979
by reaper
Replied by reaper on topic temp rises:-D
Could be a sticky thermo or just need an aux fan as you dont get much airflow going slow offroad
22 Dec 2012 15:50 - 22 Dec 2012 18:24 #55982
by j999pre
Grey pick up Jimny
Replied by j999pre on topic temp rises:-D
Could try cleaning the rad as the fins hold alot of crud.
Grey pick up Jimny
Last edit: 22 Dec 2012 18:24 by j999pre.
- Nelson83
22 Dec 2012 17:59 #56000
by Nelson83
Replied by Nelson83 on topic temp rises:-D
My temp was fine for short journeys, pottering round local - anymore than 7 miles and it kept blowing the rad cap. Swopped the thermostat and rad cap and it was fine again on short journeys, but soon starting blowing again. Local garage suggested either head gasket or water pump but weren't sure, so booked it in at the main stealer. They had it best part of two weeks, pressure tested the head, checked water pump before checking the rad - apparently it was corroding internally and "floaters" were bunging up normal flow - new rad was just under 100 quid from them plus they fitted it too - i aint got time to scratch my ass, let alone fit a new rad - problem solved
the guys did say its common for this to happen, and it often happens on longer journeys or off roading as the "floaters" get stirred up a bit more
the guys did say its common for this to happen, and it often happens on longer journeys or off roading as the "floaters" get stirred up a bit more Please Log in or Create an account to join the conversation.
22 Dec 2012 20:01 #56010
Replied by suzuki jimny fella on topic temp rises:-D
will do stat and fluids and clean rad see what happens then was stat hard to change looks like a pig of a job
- Johnniehec
- Thank you received: 56
23 Dec 2012 01:19 #56034
by Johnniehec
Replied by Johnniehec on topic temp rises:-D
Cleaning the rad fixed overheating for me, took it out and soaked it in a barrel for a couple of days, lot of crud between the fins, bugger to get out without separating from the cowl. I found laying flat and forcing water down through with a hose was better that power washer, it just destroyed the fins. No evidence of any bits floating around inside.
Time to create page: 0.173 seconds
