caster correction on the rear
  • Skinhead
  • Visitor
  • Visitor
03 Dec 2012 13:47 #54733 by Skinhead
caster correction on the rear was created by Skinhead
Ok firstly i cant afford the corrected radius arms! Right ive got a 3" lift then ive fitted a lobster with a sj prop on the rear, the problem is the prop is pushed all the way in with no play, so when im offroading its pushing my transfer box forward. If i put the caster correction bushes on the rear how much play do you think that will give me on the rear prop?
  • vitara_mad
  • Visitor
  • Visitor
03 Dec 2012 13:56 - 03 Dec 2012 13:58 #54737 by vitara_mad
Replied by vitara_mad on topic caster correction on the rear
i can't see how it would give you any play in the prop lenth as the caster bushes are not going to move the axle back they only rotate it a little bit
are you sure its not a 410 prop you got as i beleive they are a little bit longer than 413/sammy front prop ???
Last edit: 03 Dec 2012 13:58 by vitara_mad.
  • Skinhead
  • Visitor
  • Visitor
03 Dec 2012 14:16 #54740 by Skinhead
Replied by Skinhead on topic caster correction on the rear
I will have to have a mesure of my mates 413 an make sure. So you dont think caster correction bushes will do anything?
  • vitara_mad
  • Visitor
  • Visitor
03 Dec 2012 14:42 #54744 by vitara_mad
i don't think they will do anything to alter the lenth of the prop
i could be wrong but i can't see how it would
  • bigoffroader
  • Visitor
  • Visitor
03 Dec 2012 15:40 #54747 by bigoffroader
Replied by bigoffroader on topic caster correction on the rear
It sounds like they are 410 props, as your middle prop needed a spacer as well.
The corrected rear bushes won't help but rear arms would as corrected arms are slightly longer which gives you a little more room as it will rotate the diff down a little meaning the diagonal length will increase but only slightly.
  • Skinhead
  • Visitor
  • Visitor
03 Dec 2012 15:55 #54748 by Skinhead
bigoffroader wrote: It sounds like they are 410 props, as your middle prop needed a spacer as well.
I was told the prop was off a 413 but if i check an it isnt and i get the right 1, would you mind helping me swap the UJ joint again?
