Holding back/ missfire and flashing EML under load
- Gaz-M
12 Nov 2012 10:42 #53010
by Gaz-M
Holding back/ missfire and flashing EML under load was created by Gaz-M
Jimny with G13B engine, whilst sitting still it will run, idle and rev perfectly. Take it a run and it immediately holds back and flashes the engine management light. It will do this for a few seconds then be ok again, but does it time after time.
For some reason i cannot communicate with it using Snap on Solus Pro, or a more basic code reader, so im left guessing with no live data!
If i unplug the Throttle position sensor it drives perfect (with EML on constant- so in limp mode?)
From what i can see its a pretty basic engine, with only throttle position sensor, MAP sensor, cam sensor and 02 sensor?
Ive unplugged 02 sensor and it still runs the exact same, changed cam sensor, changed throttle position sensor.
Only thing i havent changed is MAP sensor, im trying to get one. Made harder by the fact no local scrap yard has a Jimny so i have to wait days on parts to 'try'!! Frustrating.
Does anyone know what the ECU relies on whilst in limp mode, purely cam sensor id imagine? Still leaving me with a possibility of the MAP sensor.
Anyone got lots of experience in the engine on these little things???
12 Nov 2012 12:12 #53012
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Holding back/ missfire and flashing EML under load
So TPS wasn't at fault then.
Is the car so hard our soft top? Soft tops usually have a crank sensor too.
Split hose anywhere? Coil pack or lead?
All stuff you have probably tried though I guess?
Grey pick up Jimny
The following user(s) said Thank You: Gaz-M
- Gaz-M
12 Nov 2012 13:24 #53018
by Gaz-M
Replied by Gaz-M on topic Holding back/ missfire and flashing EML under load
I havent received/ tried your TPS yet, i managed to make what i think is a good one out of my old one and a Toyota one i bought off Ebay out of curiosity as to whether it was the same. Ill try your when it arrives, though im sure it isnt that now as problem is exact same with different TPS fitted.
Its a hard top with no crank sensor that i can see.
Cant be a coil pack or lead, as it runs perfect with TPS disconnected. Not a split hose kind of fault i dont think, its just passed MOT with good emissions and doesnt have usual air leak symptoms, although ill check to be sure.
If the EOBD worked it would help! :dry:
- goatboy
12 Nov 2012 15:07 #53021
by goatboy
Replied by goatboy on topic Holding back/ missfire and flashing EML under load
does this help?
www. rhinopower. org /diag / cel.html
Spaces in the link so spam filter doesn't get upset
12 Nov 2012 18:37 #53035
by facade
Replied by facade on topic Holding back/ missfire and flashing EML under load
Lack of go under load is one of the signs of a blocked catalyst. However, the eml doesn't usually come on.
- Gaz-M
12 Nov 2012 21:37 #53071
by Gaz-M
Cheers.
Catalytic convertor, spark plugs, leads, coils, injectors and anything mechanical can be ruled out due to the fact it runs perfectly when on 'limp home' mode. That obviously means all the basics work fine!
It has only just passed emissions for mot, so lambda sensor must be working. (Problem still there with lambda unplugged too)
Swapped cam sensor and throttle position sensor.
Surely only thing left is map sensor?
