Squealing 'Fanbelt' and Blowing Exhaust
- Smoggy
27 Oct 2012 18:02 #51447
by Smoggy
Squealing 'Fanbelt' and Blowing Exhaust was created by Smoggy
After changing the fanbelt and power steering belt I now have an annoying squealing from the front of the engine. The fanbelt had to be changed twice after the first new one melted! This was down to the alternator pully seizing and overheating the belt. Now after freeing it off with WD40 it now turns. In my head I am probably sure it is the alternator pulley causing the squealing is this most likely to be the cause or is it likely to be power steering pump?
Also since removing and putting back on the exhaust it is blowing from all the joints, is it customary to put 'joint paste' in the joins to properly seal it up before reassembly?
- dirtydogz
27 Oct 2012 18:25 #51452
by dirtydogz
Replied by dirtydogz on topic Squealing 'Fanbelt' and Blowing Exhaust
Use some paste on the backbox joint that's all i've used, but not the front joint they are spring loaded which use seal ring.
- Smoggy
27 Oct 2012 18:58 - 27 Oct 2012 19:00 #51457
by Smoggy
Replied by Smoggy on topic Squealing 'Fanbelt' and Blowing Exhaust
No eBay APP ID and/or Cert ID defined in Kunena configurationWill this fit does anyone know?
It's the one under recently viewed items dunno why it's come up like that.
Last edit: 27 Oct 2012 19:00 by Smoggy.
- trextr7monkey
27 Oct 2012 21:54 #51462
by trextr7monkey
Replied by trextr7monkey on topic Squealing 'Fanbelt' and Blowing Exhaust
Link not working on my lap top
- Smoggy
28 Oct 2012 15:45 #51482
by Smoggy
Sorry about that, not working on mine either
Now thinking about getting an uprated alternator seeing as it's goosed. Was looking at high output GV 2.5V6 one but not sure what codes I need to be looking at to ensure it will fit my M13(non VVt) engine.
- JerseyJimny
28 Oct 2012 19:22 #51498
by JerseyJimny
Replied by JerseyJimny on topic Squealing 'Fanbelt' and Blowing Exhaust
I dont like pointing the simple things out but are the new belts been adjusted properly?
Not enough tension and the belts will slip causing the noise...
It should turn 90 degrees no more no less
Always start with the simple things first
