snorkel
  • suzuki jimny fella
28 Sep 2012 19:15 #49061 by suzuki jimny fella
snorkel was created by suzuki jimny fella
what have you guys done with the seal on the door where the bracket goes
and have you got any tips on drilling the hole as have not got hole saw :-( lol
thanks
  • Joakae
28 Sep 2012 19:25 #49062 by Joakae
Replied by Joakae on topic snorkel
I used nail polish for cleaning up the painted edges, keeps the water out from under the paint.
We used a hole saw:
www.arctic-jimny.com/post/30949989506/snorkel
  • ZookFastback
29 Sep 2012 00:37 #49074 by ZookFastback
Replied by ZookFastback on topic snorkel
I used a drill for the holes, just drilled a lot and then used a file to smooth them up and cold gal to re-seal the galvanised body...
[IMG
29 Sep 2012 21:06 #49107 by suzuki jimny fella
Replied by suzuki jimny fella on topic snorkel
thanks
no the piller bracket that holds the snorkel the seal on the door has to sit on that will water go in there guys
  • ZookFastback
29 Sep 2012 22:01 #49109 by ZookFastback
Ah, my snorkel doesn't use a bracket to affix itself to the door pillar. It has a recess to fit neatly into the pillar and a bead of silicone to retain it to the pillar, so no drilling, no getting under rubber seals and the bead would break away before damaging the pillar/seal and silicone holds very strongly but has that bit of give and take! You have to use silicone to seal the connection to airbox and plug the drain hole so no additional cost either.
  • ne-crock
29 Sep 2012 23:37 #49118 by ne-crock
Replied by ne-crock on topic snorkel
I have the pillar bracket and mine doesnt seem to leak, the door must just seal around the bracket itself
Time to create page: 0.171 seconds
