Wheel Bearing NUT / 4WD failure identified
- ritchie
28 Sep 2012 10:51 #49021
by ritchie
Wheel Bearing NUT / 4WD failure identified was created by ritchie
Hi,
I've been struggling with the vacuum hubs for the 4WD. After a few checks etc I found the problem to be the wheel bearing retaining nut. The smooth outer surface of the nut is where the vacuum hubs seals for locking the 4WD, however in the past some nugget has not had the correct wheel bearing tool and used a Stilson on the nut face chewing it up therefore ruining the seal face, causing the 4WD to leak and obviuosly not work. I've tried a few botch jobs but really need a new retaining but, my question is...... Where would I get one from, I've looked around on the webbernet but had no joy??
- Sponnie
28 Sep 2012 12:46 #49024
by Sponnie
Replied by Sponnie on topic Wheel Bearing NUT / 4WD failure identified
Sounds like a main dealer Job, or motor factors.
28 Sep 2012 13:29 #49026
Replied by mlines on topic Wheel Bearing NUT / 4WD failure identified
I can get them at a similar price to the dealer.
The following user(s) said Thank You: ritchie
- markyp2000
28 Sep 2012 17:33 #49045
by markyp2000
Replied by markyp2000 on topic Wheel Bearing NUT / 4WD failure identified
have you tryed cam suzuki also where are you from im going to the scrap yard tomorrow where i no there is a jimny i could get you one and send it to you
- ritchie
29 Sep 2012 12:40 #49090
by ritchie
Replied by ritchie on topic Wheel Bearing NUT / 4WD failure identified
I'll try cam Suzuki now. But if you could get one from the scrapy I'd def buy it from you. I stay north east of Scotland past Aberdeen.
Failing the above Martin if you have access to them new I'd like to arrange something with you.
Thanks for ur replays guys
- markyp2000
29 Sep 2012 14:44 #49092
by markyp2000
just got back and theres not a lot left after a few weeks of it being there and the front axle had gone sorry
Time to create page: 0.173 seconds
