High exit exhaust
  • ne-crock
24 Sep 2012 23:09 #48696 by ne-crock
High exit exhaust was created by ne-crock
I'm thinking of getting a high exit exhaust built, brining it out my front left wing and bringing it up beside my window to match the snorkel,
has anyone done anything like this before?
  • ne-crock
24 Sep 2012 23:39 #48698 by ne-crock
Replied by ne-crock on topic High exit exhaust
bit of fumes cant hurt,
if i pipe it up with the tip facing back over they should blow behind the car?
  • ne-crock
25 Sep 2012 00:11 #48702 by ne-crock
my comment was sarcasm...
but i'm being serious about pointing the tip back over the cab would this not work?
  • Muzza904
25 Sep 2012 07:46 #48708 by Muzza904
Replied by Muzza904 on topic High exit exhaust
I think that would look pretty badass on a jimny :evil:
  • Smoggy
25 Sep 2012 07:47 #48709 by Smoggy
Replied by Smoggy on topic High exit exhaust
How you gonna get it all to fit with it coming out at front wing mate and wot will be the advantage of it. Surely if you keep the engine running a low exit pipe will still suffice even through deep water. Alternatively you could get that big lift done first then just raise the exhaust exit to come out high at the rear and you should be 2 ft clear of the ground easy.
  • ne-crock
25 Sep 2012 21:55 #48808 by ne-crock
i was thinking pipe down to origional cat, u bend back up through the enginge bay out the wing up the side of the windscreen?
but the problem is what if you dont keep the engine running where as if the exhaust is up out high along with the air intake, it would be easier to keep the engine running,
i've been out driving through fords/ broken river banks over roads today, i'll give examples with photos once i get them sorted.
say you get so far into water unable to go further you have to keep the engine revving whilst trying to switch into reverse, where as the enginge is able to idle, if exhaust out the top of the water?
it was just a thought
