breather pipes
- Tommo
10 Aug 2012 19:08 #45859
by Tommo
breather pipes was created by Tommo
for the diffs what size pipe have people used
would 13mm be about rite?
and would that be rite for the transfer box as well
what have other people done, any pics if any one has any?
and is there any thing I need to know such as the length it needs to be between the chassis and axle
I don't want it too long (will pinch the pipe and not work) or too short (will snap)
- dirtydogz
10 Aug 2012 19:51 #45861
by dirtydogz
Replied by dirtydogz on topic Re: breather pipes
- markyp2000
10 Aug 2012 20:13 - 10 Aug 2012 20:35 #45864
by markyp2000
Replied by markyp2000 on topic Re: breather pipes
Last edit: 10 Aug 2012 20:35 by markyp2000.
- markyp2000
10 Aug 2012 20:37 #45865
by markyp2000
i think the gbox and tbox pipes are 6mm or 8mm just got that from halfords thay are not easy to do i had to lower the gbox and tbox to fit them
- Tommo
10 Aug 2012 22:12 #45874
by Tommo
Replied by Tommo on topic Re: breather pipes
as the axle breather have a cap over them
why is there any need to put pipes on if no water will get in?
- markyp2000
10 Aug 2012 22:40 - 10 Aug 2012 22:44 #45878
by markyp2000
if water didnt get in why would i put pipes on it belive me water gets in if air comes out of a beather then water can get in knock the caps off with a screw driver and fit a hose on it other wise you will be replacing diff etc
Last edit: 10 Aug 2012 22:44 by markyp2000.
Time to create page: 0.198 seconds
