Does anyone sell speedo adaptors separately?
  • Paul4x4
05 Aug 2012 15:57 #45511 by Paul4x4
All I can find is some full sammy t-case fitting kits, but I think those are a little bit over priced being just a few bolts and couple pieces of metal, considering I could fab my own mounts in about two hours so I don't feel like buying those full kits. :whistle:
So it would be nice to be able to buy just the speedo pickup gear if possible. I have to make my own if there's nothing I can buy... :dry:
  • JimnyX19
05 Aug 2012 16:11 #45513 by JimnyX19
No eBay APP ID and/or Cert ID defined in Kunena configurationNot 100% if you can buy a speedo seperate but there is a full one here on eBay
  • X-Eng Simon
05 Aug 2012 18:46 #45532 by X-Eng Simon
Replied by X-Eng Simon on topic Re: Does anyone sell speedo adaptors separately?
I made my own by drilling a ring of holes in an X-Brake disk then mounting the original pickup close (0.5mm) by. You can do exactly the same thing by drilling a ring of holes in the circumference of the drum and mounting the pickup at the top. This also helps the drum centrifuge all the mud out!
I drilled 8mm holes IIRC.
There are piccies on here somewhere in one of my posts.
Si
06 Aug 2012 12:32 #45561 by Johnniehec
Paul, PM rockwatt, I'm sure he would oblige.
John.
06 Aug 2012 12:37 #45562 by Johnniehec
Or,
"Poor mans speedo converter" article .
www.bigjimny.com/images/documents/poor-mans-jimny-speedo.pdf
John.
  • Rockwatt
06 Aug 2012 17:58 - 06 Aug 2012 18:04 #45577 by Rockwatt
Johnniehec wrote: Paul, PM rockwatt, I'm sure he would oblige.
John.
Somebody call :-)
Yes I can do the speedo drive separately no problem.
but it's only £140 more for the whole kit !!
I also have an offer on at the moment of half price fitting kit if purchased with one of my 4.16 rocklobsters.
These will be the very last lot of joined gears as I have secured a deal with the Suzuki oem gear supliers for new one piece gears in a variety of ratios, so these will be the last batch of cheep ones I ever do so grab um while I've got um
Last edit: 06 Aug 2012 18:04 by Rockwatt.
