DTC to suzuki codes
  • Knifeman
25 Aug 2010 12:35 - 25 Aug 2010 12:38 #4395 by Knifeman
DTC to suzuki codes was created by Knifeman
I have an engine error P135 (telling oxigen sensor). I replaced the Oxigen sensor with a new one (the one on the air intake), reseted the ECU and keep on getting the same error... I'm not sure if the scanner tools gives the right info... so is there any table available to map the standard DTC codes to the suzuki codes in the manual
(ow yes, I do not seem to be able to get the flashing engine sign as described in the manual by making a short circuit on the connector ... strange)
thanks guys !
if you see this readings, what do you think could be wrong with the engine? am I mistaking and is the heated oxygen sensor the same as the Lambda sensor ?
Last edit: 25 Aug 2010 12:38 by Knifeman.
25 Aug 2010 15:37 #4397 by facade
Replied by facade on topic Re:DTC to suzuki codes
The oxygen sensor is the one on the exhaust manifold: a lambda sensor, it says the heater circuit has failed. (I think that is sensor 1: sensor 2 should be the one after the catalyst)
  • Knifeman
25 Aug 2010 18:38 #4401 by Knifeman
Replied by Knifeman on topic Re:DTC to suzuki codes
so is there a way to verify this, or could the failing sensor be the consequence of a failing catalist? the sensor is priced 130 euro's here, so I'd rather don't fix this by trial and error ;)
greetings
26 Aug 2010 05:21 #4403 by mlines
Replied by mlines on topic Re:DTC to suzuki codes
As Facade says, its the heater circuit of Sensor 1, the one high up on the exhaust manifold.
The diagnostic is below, if you have a meter you can do a resistance check of the heater.
If it is this part then there are some cheaper generic parts around that can be used instead of the expensive Suzuki ones.
26 Aug 2010 09:02 #4407 by facade
If you are very, very lucky, it may just be a corroded connector. Follow the wires from the sensor up to the back of the engine, part the connector, and check for corrosion/ broken or damaged wires.
As Martin says, you can buy a generic part, I believe they are a 4 wire sensor, cut the original wire and join to the bare wires on the new one. (Someone has already done this on mine, and it works perfectly.)
BTW, what software are you using to read the codes?
I bought Digimoto 5, I was seduced by the pretend dashboard dial display and the performance measuring section, but really it is no better than the open source scantool.net. (Just cost me £25 :dry: )
  • expense
05 Apr 2011 21:01 #14571 by expense
Replied by expense on topic Re:DTC to suzuki codes
Ive had the rear sensor replaced, drove 2 miles, sensor light came on again, garage tells me its the front one now. can holes in the exhaust cause affect the sensors at all!? - whats the best plan of action please?
