Transfer boxes (Rocklobster)
- Dave c
- Visitor
Has anyone ever tried to uprate the chain system ??? and change the ratio to run bigger wheels.
Surely with 410 boxes becoming rarer there could be a market for a bolt in uprate kit.
Only a thought !!!!! on a boring Saturday evening
Your thoughts
- supergaz
- Visitor
The way around the 410 box is to use a 413 or samurai box and install a gearset like the trial gear sets.
- Rockwatt
- Visitor
Funny you should say that as lots of people like the ubber quietness of the chain drive I was thinking of spacing a case out and fitting a double chain. And also looking at lower gearing than is already available.Dave c wrote: Loads of chat about transfer box problems associated with the infamous drive chain.
Your thoughts
Also looking at scratch built cases from billet but they are a way off yet. Enjoy the lobsters while they are still about and when they have all gone then there will be a replacement I can assure you.
Your thoughts
Cor blimey Sir - talk about finger on the pulse!!!
- Dave c
- Visitor
The trouble with a straight ratio change is that everything is sized for the orginal design and re-sizing results in more power through smaller cogs which can lead to chain slip.
Rockwatt is talking of a different solution
