Transfer box 51 reg jimny
  • Freer
  • Visitor
  • Visitor
23 Jun 2012 15:57 #42801 by Freer
Transfer box 51 reg jimny was created by Freer
I have a 51 reg manual jimny which has picked up a problem. Every so often i can be driving along in 2H and there will be a grinding from the drive train. Once i slow down to about 10mph there is a clunk and something sounds like it re-engages. I might then be fine for days.
The vacume hubs are working fine and it selects 4H and 4L fine.
The only thing i have noticed which i am not sure is correct or not is if it is in 2H and i go underneath it i cannot turn the rear prop shaft as expected, but this is the same for the front prop shaft. I expected the front prop shaft to be dis-engaged and able to spin by hand. Is this correct or not.
  • supergaz
  • Visitor
  • Visitor
23 Jun 2012 16:18 #42802 by supergaz
Replied by supergaz on topic Re: Transfer box 51 reg jimny
You wont be able to turn the rear prop if the rear wheels are on the ground.
You should be able to turn the front if the front hubs are not engaged and the car is in 2H.
A replacement transferbox should be very cheap as a'lot of us bin them.
Remember not to engage 4L or 4H on a dry surface or it will cause damage.
Welcome to Bigjimny.
  • reaper
  • Visitor
  • Visitor
23 Jun 2012 18:12 #42806 by reaper
Replied by reaper on topic Re: Transfer box 51 reg jimny
I will have one for sale as soon as i fit my lobster box pm me if interested :)
24 Jun 2012 07:20 #42817 by robs5230
this sounds like an issue that has been queried quite a few times before on here. i have had a similar noise, usually brought on by going over a bump and i think its the vac hubs not completely coming back out of lock position. i have bought manual hubs to cure this
standard jimny - for now
  • Freer
  • Visitor
  • Visitor
24 Jun 2012 12:24 #42823 by Freer
Replied by Freer on topic Re: Transfer box 51 reg jimny
I think you might be right. I will have a look into wether the hubs are dis- engaging properly. Thanks for the reply. Cheers ads
24 Jun 2012 21:18 #42848 by robs5230
my manual hubs have done the trick. no noises happy days
Time to create page: 0.159 seconds
