removing spare wheel carrier from rear door.
- Thank you received: 77
11 Jun 2012 20:16 #42191
by robs5230
standard jimny - for now
removing spare wheel carrier from rear door. was created by robs5230
hi, i am thinking about removing the spare wheel carrier from the rear door to save the door hinges. has anyone done this and what did you do about the holes ??
cheers rob
cheers rob
- myers647
11 Jun 2012 20:24 #42192
by myers647
Replied by myers647 on topic Re: removing spare wheel carrier from rear door.
Hi mate I did this for a while but then decided to put it back on. All I did was screw the bolts back into the holes.
Thanks
James
Thanks
James
11 Jun 2012 20:32 #42193
by robs5230
Replied by robs5230 on topic Re: removing spare wheel carrier from rear door.
ahh ! are the holes captive or does the trim panel inside have to be taken off ?
- VAXXi
11 Jun 2012 20:36 #42194
by VAXXi
Replied by VAXXi on topic Re: removing spare wheel carrier from rear door.
There's no need to remove the trim.
- myers647
11 Jun 2012 20:46 #42195
by myers647
No mate if you really feel the need to remove the wheel off the door then just unscrew all the bolts remove then carrier and then screw the bolts back into the holes in the door. easy 5 minute job.
Thanks
James
Thanks
James
11 Jun 2012 21:03 #42196
by robs5230
the wheel's been off for a month . the bracket looks like it will impale someone
when i go off road the spare will be inside. cheers lads
Time to create page: 0.773 seconds
