PCD of FRont Discs for a 54'plate Jimny
- Thank you received: 115
12 Aug 2010 14:04 #4195
by maverick
Jalapeño, IISY?
PCD of FRont Discs for a 54'plate Jimny was created by maverick
It seems there's two PCD's for front dics on a Jimny
107mm and 108mm
Any idea which my '54 plate Jimny would have, stave off my tsaking off the discs to find out?
107mm and 108mm
Jalapeño, IISY?
12 Aug 2010 14:17 - 12 Aug 2010 15:00 #4196
Replied by mlines on topic Re:PCD of FRont Discs for a 54'plate Jimny
I think you have been given the wrong info.
The PCD is the same. All of this range of Suzukis (SJ, Jimny, Vitara) are the same, you can happily interchange the wheels.
However, the centre hole diameter of the disk changes, 107mm to 108mm
Up to VIN Number 00203804 they are 107mm
From VIN Number 00203805 onwards they are 108mm
Last edit: 12 Aug 2010 15:00 by mlines.
12 Aug 2010 14:29 #4197
by maverick
Jalapeño, IISY?
Replied by maverick on topic Re:PCD of FRont Discs for a 54'plate Jimny
Yeah - sorry Martin...
I'm not a mechanic ..
What VIN mumber am I - Where is it on my Jimny?
Jalapeño, IISY?
12 Aug 2010 14:30 #4198
by maverick
Jalapeño, IISY?
Theres a VIN on my log book - ends with 00190760 ... is that it?
Jalapeño, IISY?
12 Aug 2010 14:45 #4199
I am not an engineer either, just an IT consultant with a degree in "google"
VIN number is in a number of places...
1. Log book
2. Inside windscreen when viewed from outside
3. On plate inside engine compartment
4. on chassis rail
They should all be the same!
1. Log book
4. on chassis rail
12 Aug 2010 14:50 #4200
by maverick
Jalapeño, IISY?
What am I 107 or 108?
Jalapeño, IISY?
Time to create page: 0.150 seconds
