Oil in the brake drum.
- Sam_
26 May 2012 11:00 #41188
by Sam_
Oil in the brake drum. was created by Sam_
Does Oil in the brake drum mean I've got a shot rear wheel bearing?
The brake cylinder doesn't seem to be leaking.
Any ideas?
i wanted to go to slindon tomorrow but now it's not looking likely
(it was kingpin bearings last time)
Any ideas?
- rjd1
26 May 2012 11:20 #41189
by rjd1
Replied by rjd1 on topic Re: Oil in the brake drum.
unbolt clean old seal use instant gaskit till you get proper seal at least it will get you out playing
- Sam_
26 May 2012 11:41 #41190
by Sam_
Replied by Sam_ on topic Re: Oil in the brake drum.
Cheers for that, It doesn't feel like theres any play in the bearing so could it be just a seal?
If I unbolt it all would I have to remove the slave cylinder too?
- Sam_
26 May 2012 20:15 #41204
by Sam_
Well couldn't stop the leak, so has anyone got the part number for the oil seal?
26 May 2012 21:21 #41205
Replied by mlines on topic Re: Oil in the brake drum.
In my online shop, but I would guess the bearing is also not good
Sent from my HP Touch pad using Tapatalk
- Sam_
26 May 2012 21:34 #41207
by Sam_
well i can't feel any play in it what so ever, so I'm hoping its just the seal!
