More Bearings....
  • ooky_123
01 Aug 2010 18:48 #4013 by ooky_123
More Bearings.... was created by ooky_123
The wife moved our little jimny today, and I noticed a small pool of oil on the floor ... After going though all the metal oil leak possible problems in my head, I was confused ... Engine dry ... Gearbox .. Dry ... Front swivel joints ... Dry ... Kingpins ... Dry
So .... further inspection underneath revealed a thin sticky line up the inside of the rear wheel, and a trail comming from inside the drum.
Looks like a rear wheel bearing / seal... Time to spend more money with Martin ......
  • colin f
01 Aug 2010 19:36 #4014 by colin f
Replied by colin f on topic Re:More Bearings....
you have my sympathy, these things eat bearings way too quick!!
  • ooky_123
01 Aug 2010 20:13 #4015 by ooky_123
Replied by ooky_123 on topic Re:More Bearings....
I suppse, given the abuse ours has recieved over the last 18 months ... Its not suprising we have only had the following fail ...
1 front Wheel Bearing
1 Starter Motor
4x4 vacuum bits fail
one clutch
and a set of brake disks / pads.
Add a rear wheel bearing to that
  • colin f
01 Aug 2010 20:16 #4016 by colin f
in 11 months (3000 miles) mine has had a complete set of bearings, front, rear and kinpins........
it is getting on my nerves now!!
  • ooky_123
02 Aug 2010 07:19 #4021 by ooky_123
Wow ... thats a lot !!!...
Any reason for it eating Bearings ? Our first Jimny lasted 4 years and, although was never taken swimming, was offroaded regularly. (bought from new)
Our current Jimny has already done 64,000 miles, so im not that surprised its needed a few components, and also given its been used almost solely offroad.
Did you change them yourself ? if so, are they hard to do ?
02 Aug 2010 08:24 #4023 by facade
Replied by facade on topic Re:More Bearings....
Make sure the axle breather isn't blocked first, if it is, it can force oil out of the seals at the wheelbearings.
Time to create page: 0.188 seconds
