Rock Sliders
17 Feb 2009 18:46 #375 by kirkynut
Rock Sliders was created by kirkynut
Hello All,
I'm starting to get things together to have my Jimny ready for a trip to the Lakes and some hardcore greenlaning with plenty of rocks involved!!!
As such I need some Rock Sliders and could do with some advice.
I am looking at getting some ready made up ones from Darren at KAP and he has told me that they are the same as the sliders that make up that part of his cages. I can see a few of you have cages and suspect they may have come from KAP, I kno your vehicle has some KAP bits on it Martin.
Can anyone tell me how they are welded onto the chassis - I know with a welder obviously, but are they just butted onto the chassis or do they have triangular sections to brace it too etc... I also appreciate that it depends on the quality of the welding, but assuming it's of top quality, how strong are they?
Cheers for any help y'all can offer.
Kirky
17 Feb 2009 21:08 #376 by mlines
Replied by mlines on topic Re:Rock Sliders
Mine is a KAP roll cage and yes, it is clear that the lower bars of the Roll Cage form a Rockslider.
On my Jimny they are simply box section.
A long piece of box section forms the slider and then shorter peices of box section go back to the chassis rails. These short supports have a flat plate welded on the end which is then pushed flat against the side of the chassis rail and welded.
Mine are pretty strong, however I understand that KAP uses 2 support arms as standard, one at each end. The previous owner added a 3rd central support arm to help stiffen it up.
18 Feb 2009 13:48 #377 by kirkynut
Replied by kirkynut on topic Re:Rock Sliders
Martin,
Thanks for that, I wondered if they would have liek a spreader plate welded tothe end that then welds to the chassis and from what youhave said they do. I should think they are ok with just the 2 pieces of box section when being used just as sliders and can understand why someone has added the third for the cage on yours.
I shall order some up from Darren in the next few weeks then and get a good local welder to weld them on as I've never welded before and have no kit.
I'm having a new clutch fitted as we speak and decided to let my local trustworthy garage do it for a couple of hundred plus the dreaded and the clutch after reading your write up on doing the job and seeing the access to the starter etc!!! It's also too cold to be changing clutches in a damp cold lock up!!! - I'm not as enthusiastic (stupid) as I used to be - there was a time when I'd lay old carpet over the snow to be able to roll about under my projects - they are gone with my boyracer days though.
With the clutch, the sliders, all my TBR protection plates, the KAP 3 inch lift and the 215/15 MT's along with something on the roof to mount waffle boards we'll be all set for our next adventure in the Lakes and the first in the Jimny. We'll be going at the end of April and I will have many pictures for you then.
Thanks again
Kirky the waffler
19 Feb 2009 20:06 #378 by mlines
Here are some pictures.
22 Feb 2009 15:54 #382 by kirkynut
They look strong enough, thanks for that.
I might take up a friend's suggestion and get some tree sliders welded onto them outside of them too - just in case!!!
Kirky
13 Jul 2009 19:30 #993 by Baz2236
Replied by Baz2236 on topic Re:Rock Sliders
Sorry to bring up an old thread, I am lookin at them Sliders from KAP how far do they stick out and how close are they to the seal I dont have the plastic bit of trim and the bottom of the door so wondered if they will sit close to the seal.
Thanks,
Baz
