Swivel seal ?
- Gromit
- Visitor
07 Apr 2012 08:53 #37031
by Gromit
Swivel seal ? was created by Gromit
Ok so looking at changing the kingpin bearings and swivel seals so I"ve downloaded the guide off here.
What I don't understand is how you get the swivel seal on as it doesn't have a cut in it like the retaining rings do ?. Do I cut it or what ??.
- Sam_
- Visitor
07 Apr 2012 13:34 #37037
by Sam_
Replied by Sam_ on topic Re: Swivel seal ?
I'm just about to do my swivel seals too.
In the Suzuki manual it does say to cut them but I wanted to double check too!
07 Apr 2012 14:54 #37041
by facade
Replied by facade on topic Re: Swivel seal ?
If you are changing the swivel bearings, they simply slightly stretch over the ball with the swivel housing removed.
Cutting them is to get them on with the housing in place. I suppose you could glue them back together with super glue and put the cut at the top :whistle:
- wanderinstar
- Visitor
07 Apr 2012 15:48 #37046
by wanderinstar
Replied by wanderinstar on topic Re: Swivel seal ?
I had a word with Martin and he said that when you have everything stripped down the rubber seal will stretch over the housibg. The metal "rings" are already cut so you place those to the top
Why cut a seal if you don't have too?
07 Apr 2012 16:14 - 07 Apr 2012 16:16 #37048
by kirkynut
Replied by kirkynut on topic Re: Swivel seal ?
Yes they stretch over the swivel balls once you've got the steering knuckle off.
They are crap though, nowhere near as good as the old SJ ones, I've replaced mine twice now and have given up until they get really bad as they are not good to start with. It's just a bit of rubber dragging over a bit of metal, that due to it's design is not dead smooth, so it gets worn.
If you are keen, rub your swivels down with fine emery to get them as smooth as you can and if you are really keen paint them to make them dead smooth. T'will make them last longer and seal better.
Last edit: 07 Apr 2012 16:16 by kirkynut.
- Gromit
- Visitor
07 Apr 2012 17:48 #37052
by Gromit
Replied by Gromit on topic Re: Swivel seal ?
Cheers guys, gonna try rubbing them smooth then. Must admit that I have been putting this job off for ages but n/side one is now pissing grease out so best get that one done at least !
Time to create page: 0.160 seconds
