More starter Woes
  • ooky_123
10 Apr 2010 08:29 #3095 by ooky_123
More starter Woes was created by ooky_123
Right, I have some strange happen ings with my starter motor..
First of all, it was changed for a new one in December 09 and has only done 4 offroad trips.
Secondly, in January, the origional Battery was thought to be faulty so a new Battery was fitted (OEM fitment).
Since then, The Jimny has either "clicked" when attempting to start, and eventually, it has fired, and the car started.
More reciently, the starter just "clicks", but refuses to fire.
I finally managed to get the starter off and clean the Much out of it, and, attached to a bench Power supply (1000 cA battery) it fires fine.
Now, the battery is taking charge, and holding charge fine too, but when the starter was replaced, the starter will "click" once, and on the second twist of the key, fire and start the car.
This leaves me with 3 Questions ...
1. Is starter duff ?
2. Is battery insufficient ?
3. Demonic posession ??
So How do I resolve the problem ?
Im thinking ...
Another new starter ?
or
www.tayna.co.uk/Numax-CXV-X-1000-Amp-P7632.html
or
www.tayna.co.uk/Numax-CXV24MF-P3126.html
or another Origional fit one ..
www.tayna.co.uk/batterygroups/393/545157...Batteries-page1.html
... Or a Priest ???
10 Apr 2010 18:24 #3099 by kirkynut
Replied by kirkynut on topic Re:More starter Woes
I have just had exactly the same trouble!
Fortunately for me, Lindz (my partner)'s step dad has a starter motor and alternator re-building company and when I got the Jimny the Starter was sticking on for a second or so after I let go of the key, so he cleaned it out of brake dust and gave it a check over. That was not too long ago, about 10 months and 5000 miles.
I went to take the car for the firring of the raer ORA bumper by the guy who has done my cage and winch bumper so he could strenthen it up ready for hte cage and "CLICK".
I still had our SJ and had just topped up it's battery and it was on the garage floor, so I jump started it and threw it in the back with leads for my welding master!
Then it started but was slow and after he fitted the cage "CLICK". It jump started again and then I fitted my NUMAX 86AH 1000CCA battery (great minds) and the problem was solved.
It was not the battery though!!! The battery was fine, fully charged and started the SJ well.
It was not the earths being dirty - I cleaned every damned one of them!
It was the poitive connection on the battery, which I took apart and replaced when I fitted the new battery in the boot and a new connector at the front to take the new positive and negative leads that go the length of tghe vehicle on top of it's chassis.
So in short - which I'm not famed for!!! - Clean your postive connection up and all your earths in case it's an of them.
I have seen what you drive through so your earths could be a little rusted up where they meet the body, chassis and gearbox.
You've bench tested the starter, so you know it's not that. What's the battery voltage when the engine is off? Should be at least 13.5 fully charged.
12 Apr 2010 14:21 #3106 by Obarno
Replied by Obarno on topic Re:More starter Woes
Hi - don't know if this will help, or if it's a red herring! SJ's typically suffer from 'clicky starter' and it's because the relay on the starter is connected directly to the ignition switch, which after time and dirt, doesn't provide a good connection to the starter. The remedy is to install a relay operated by the ignition switch, which is then connected to the starter. This provides a good power supply to the starter relay. The point is though, that I don't know if Jimnys use the same type of wiring arrangement as the SJ!
12 Apr 2010 18:41 #3109 by kirkynut
I don;t think Jimny's are quite as basic as the SJ's and they tend not to suffer with these maladies, so I think it will still boil down to cleaning up all connections and earths.
  • ooky_123
13 Apr 2010 04:31 #3114 by ooky_123
Replied by ooky_123 on topic Re:More starter Woes
Even more strange, I don't think it's connections ... The battery checks out fine, the current draw on the starter isn't too bad either. I'm going to stick a massive battery in place of the halfrauds one I fitted 3 months ago as it seems to be the battery isn't able to kick out enough cranking amps (300 it says)... To turn over the car.. Sometimes it does, other times it won't.
Local garage cleaned up all the earth points for me and I cleaned up the battery contacts
  • ooky_123
13 Apr 2010 04:33 #3115 by ooky_123
Time to create page: 0.176 seconds
