Selector Stick (gear stick) wobble
  • blakey2000
11 Dec 2011 22:50 - 11 Dec 2011 22:51 #27949 by blakey2000
Selector Stick (gear stick) wobble was created by blakey2000
Hi there all,
has anyone had a problem with there gear stick haveing excessive wobble? when in gear, and out of gear.
i can only see it to be 2 proabable causes its either the seat spring or the lower controle seat.
has anyone come across this problem or fixed it before?
Attachment gearstick.jpg not found
Last edit: 11 Dec 2011 22:51 by blakey2000. Reason: spelling
  • darthloachie
12 Dec 2011 08:05 #27959 by darthloachie
Replied by darthloachie on topic Re: Selector Stick (gear stick) wobble
you'll also get it if the transfer box is moving on its mounting bushes
12 Dec 2011 08:27 - 12 Dec 2011 08:27 #27962 by mlines
Your picture is incomplete!!! - part 36 is a candidate, the rear remote rubber mounts (2 off) - £24 each (genuine Suzuki parts from me) or someone will probably tell you a cheap Landrover part that fits.
Attachment gearbox.jpg not found
Last edit: 12 Dec 2011 08:27 by mlines.
  • blakey2000
12 Dec 2011 08:58 #27968 by blakey2000
Replied by blakey2000 on topic Re: Selector Stick (gear stick) wobble
what manual is that picture from, i cant seem to find it in my manual that i have. and i cannot view that picture its over compressed and practically unreadable for me
cheers, Blake
12 Dec 2011 09:21 #27969 by mlines
Its the parts manual,
Hopefully here it is in better quality
Attachment remotet.pdf not found
The following user(s) said Thank You: blakey2000
  • blakey2000
12 Dec 2011 09:27 #27970 by blakey2000
Thank you, for that and yes that one was much better,
i will check out that part tomorrow when i pull the gear stick apart/off to see if mine is worn or damaged.
Cheers, Blake
