springs
- r_ogilvy
08 Dec 2011 09:04 #27527
by r_ogilvy
springs was created by r_ogilvy
i have been playing under my making sure everythings ok, i have a bit of a lean an many people say about the lean.
am i being stupid? because the front 2 springs are different lengths? its a 2" + spring lift
but theres about an inch difference, has this been done to sort the lean? or is it a wrong spring? :blink:
a week or 2 ago i done a post about steering wandering, would this make it wander? as i do have castor correction bushes.
08 Dec 2011 09:08 #27528
Replied by mlines on topic Re: springs
There is a 32kg difference between the LHS and RHS of the car. Therefore you will typically see a difference in the spring length when measured on the car, the real check is when the springs are removed and laid side by side, then you can see if one of your springs is "tired"
- r_ogilvy
08 Dec 2011 09:15 #27530
by r_ogilvy
Replied by r_ogilvy on topic Re: springs
iv had them out just now and laid them down and theres a good 1" difference in the to,
i have a invoice in my folder as the lift was on it before i had bought it, its dated for the march 21, 2011
from jimnybits?
from jimnybits?
08 Dec 2011 09:21 #27531
There has been talk in the past of some kits including "correction" for this weight difference, perhaps Jimnybits does this. I am sure Rus (BlueJimny) will be along shortly to reply.
- r_ogilvy
08 Dec 2011 09:25 #27532
by r_ogilvy
ok, be worth knowing, the longer of the springs has been placed in the drivers side?!
- darthloachie
08 Dec 2011 12:03 #27536
by darthloachie
yep thats correct
Replied by darthloachie on topic Re: springs
r_ogilvy wrote: ok, be worth knowing, the longer of the springs has been placed in the drivers side?!
yep thats correct
Time to create page: 0.340 seconds
