exhaust dimensions
  • myers647
01 Nov 2011 21:34 #24994 by myers647
exhaust dimensions was created by myers647
Hi does anyone know the dimensions of the rear exhaust pipe. Im getting a small front exhaust box from a guy in leeds to replace the back box on my jimny, to make it sound a bit beefier, but he wants to know some dimensions width length etc so he can find me one suitable for the job. he is only charging me £15 including P&P which i think is a good price.
thanks
james
  • Back in Black
04 Nov 2011 06:06 #25131 by Back in Black
Replied by Back in Black on topic Re: exhaust dimensions
I'll do some measuring tomorrow and let you know. I'd be interested in what he comes up with, I'm in need of a replacement, and want a smaller back box.
I'll update when I've got the dimensions
  • myers647
04 Nov 2011 09:06 #25136 by myers647
Replied by myers647 on topic Re: exhaust dimensions
Thanks mate let me know. Il see what he comes up with and let you know the results.
Cheers
James
  • Back in Black
05 Nov 2011 13:55 #25189 by Back in Black
Hi. The original box is 16.5" long and is oval at 9" wide and 6" high (overall length of the box - including the inlet to the exit is around 23"). The bore of the exhaust pipe is 4cm/1.5". Where the box connects to the pipe there is a collar type thing on the pipe and the box where they bolt together. I'd recon to replace with another box you'd have to cut the pipe off an inch before the collar - this would mean you need something approx 25"/64cm long and about 5"/13cm wide/tall. The lenght of 64cm with a rightangle bend on the end which is needed to curl around the recovery point, but can't be much longer as the pipe bends through 90 degrees 5 inch after the join back towards the engine. I have tried to do a picture below, hopefully enough information to help?
Attachment backbox.jpg not found
  • doncarlyon
07 Nov 2011 08:15 #25294 by doncarlyon
Replied by doncarlyon on topic Re: exhaust dimensions
Has anyone removed the middle silencer and replaced it with a straight through pipe?
  • p1ngu32
07 Nov 2011 11:42 #25300 by p1ngu32
Replied by p1ngu32 on topic Re: exhaust dimensions
When my cat removed its self i welded in a straight bit of pipe, its made the exhaust note very raspy on hard accelleration and decel. the centre silencer is just a small resonator box isn't it? Dont know if that would make much odds maybe more cabin noise?
Time to create page: 0.329 seconds
