Jimny towing limit.
  • Nobby22
02 Oct 2011 12:09 #22915 by Nobby22
Jimny towing limit. was created by Nobby22
Hi all
I was looking into towing with the old jimny. According to the manual it should only tow 450kg braked and 350kg un-braked. However if you look at the VIN plate its gross towed mass is 2720. So potential you could tow up to 1300kg? I know they recomend only towing 85% of the vehicles weight. No need to tell me towing in a jimny is not ideal because using a nother car is not an option. I just want to know what i can tow legaly in this country, because even a 450kg trailer is crap! I have been on towing websites that give 1300kg as a max figure. Is it up to the country they are registered in to decided its max towing limit? You would think this sort of thing would be made cristal clear.
Cheers
Nobby
02 Oct 2011 12:37 #22918 by Obarno
Replied by Obarno on topic Re: Jimny towing limit.
I have just had a look at the V5 for my Jimny and it gives a towing weight braked of 1300kg and unbraked of 350.
The following user(s) said Thank You: Nobby22
  • Nobby22
02 Oct 2011 12:38 #22919 by Nobby22
Replied by Nobby22 on topic Re: Jimny towing limit.
Extract from manual.
"If there is a regualtion which specifies maximum trailer weights greater than the capacities shown above; vehciles sold in these countries have towing capacities which match the maximum trailer weight permitted"
So does that mean the "maximum trailer weight permitted" is 1300kg? Surely the VIN plate can not be wrong?
So confusing. :S
Nobby
  • Nobby22
02 Oct 2011 12:40 #22920 by Nobby22
Obarno wrote: I have just had a look at the V5 for my Jimny and it gives a towing weight braked of 1300kg and unbraked of 350.
Ah cool. ;) Thing is, i may be wrong, i carnt find trailers for sale in the uk within say the 500kg to 750kg mark with brakes. Do they come with brakes and its just not stated in the adverts?
Nobby
02 Oct 2011 13:05 #22921 by Obarno
I think a lot of trailers up to 750kg are unbraked. Have you had a look at the Ifor Williams website - I'm sure you would find some useful information there?
  • downhilldude
11 Oct 2011 09:20 #23478 by downhilldude
Replied by downhilldude on topic Re: Jimny towing limit.
It says 1300kg, quite a bit for a wee car like that. But we managed to tow 2500kg with 5 people in the car! It was a bit dodgey trying to stop in the rain, so we had to drive in 4wd to the centre diff kept all 4 wheels braking! I wouldn't recommend doing this that often but it was the only (safe ish) way we could tow home. Tough wee cars!
Time to create page: 0.166 seconds
