side lights / tail lights / dash lights not workin
  • booomer
22 Sep 2011 15:50 #22350 by booomer
Hi guys, i know there have been posts about this before but none of them relate directly to the problem i have got. Basically the tail light fuse blows every time you turn the side lights on. i have checked all the wires i can see under/behind the dash, under the bonnet, behind the rear passenger door card and in the rear bumper. All of it looks fine. i have fitted a new indicator/light stalk unit behind the steering wheel as the old one was falty. Anyone got any other ideas? for some annoying reason i cant find a single wiring digram that i can download.
cheers
22 Sep 2011 18:42 - 22 Sep 2011 18:42 #22360 by Halford
Hi Booomer, welcome
attached a mini pdf file from manual re: lights
Attachment lights.pdf not found
you can download the a full manual from suzuki info which includes wiring diagrams
good luck
Last edit: 22 Sep 2011 18:42 by Halford.
  • mcjimny
22 Sep 2011 20:32 #22369 by mcjimny
Its shorting somewhere. Mine did it where i had put the towbar on and there was some slack in the wiring, it had melted on the exhaust and would short out once hot.
Its apparently quite common for the wires to wear through behind the rear light cluster where it goes into the body.
I hate electrical problems, good luck with the cable chasing!
23 Sep 2011 15:39 #22399 by facade
Did this problem start when the new switch was fitted?
Or did you fit the switch because of the problem.
What was the last thing you did before the problem started?
I had a problem when I fitted a new bulb once. Turned out the bulb was 6V, just blew the fuse, rather than the bulb.
  • booomer
25 Sep 2011 14:03 #22483 by booomer
Thanks for the replies guys, i bought the car with the problem so its not a result of something i have done. Even with the front lights unplugged and the rear bumper disconnected (electrically) it still blows the fuse, that makes me think it isnt a bulb or any of the bumper wiring.
  • booomer
25 Sep 2011 14:18 #22484 by booomer
What/where is the ECM that is pictured on the wiring diagram?
