M/T's on s standard Jimny and other Q's
16 Oct 2008 15:29 #221
by kirkynut
M/T's on s standard Jimny and other Q's was created by kirkynut
Dear All,
I am new to this forum having been running an SJ until now. It's blown it's head gasket and is indicating it's not wanting to do the long distances on the road and then hardcore off roading and then driving home again!
So I am considering getting another Jimny and using that instead.
I had one before and found it no good as standard for what we wanted to do as it was grounding out on the radius arms in ruts with 205/70/15's on it.
I was told that you caould not put M/T's on a standard Jimny without lifting it and didn't want to spend the money on it at that time so sold it.
Now the SJ has died I am having to re-consider.
Rhino-Ray has told me that I can use 195/80/15 M/T's on a standard Jimny with no problems.
To test this theory, today I took the wheels off our SJ with 195/80/15 Colway M/T's on them and out them on my partner's mum's Jimny.
Ground clearance was greatly imrpoved as the diameter of these is about 1.5 - 2 inches larger, but the clearance of the tyres in the wheelarches look too tight and I felt that the arches would get could and ripped apart.
Please can you tell me the deal with this please folks?
Can a standard Jimny run 195/80/15 M/T's with no arch trimming or not?
Also.... How strong are the halfshalfs on Jimny's? Do they snap when treated roughly or are they as strong as out SJ's?
Also.... Do early - ie:the cheapest to buy Jimny's have ABS?
Thanks for any help you can give me.
Rob
Rob
16 Oct 2008 16:12 #222
Replied by mlines on topic Re:M/T's on s standard Jimny and other Q's
Well the standard tyres on a Jimny are 205/70/R15.
70% x 205 = 153mm or 6 inches.
6 inches + 6 inches + 15 inches = 27 inches - therefore the diameter of the standard tyres is 27 inches.
Your new tyres are 195/80/15
80% x 195 = 156mm or 6.1 inches
6.1 + 6.1 + 15 = 27.2 inches
So, as RhinoRay says you should be able to use the tyres with no problem as there is hardly any size difference.
However, tread pattern and size makes a difference, perhaps your old tyres are worn and the newer tyres are newer. Perhaps its a particularly chunky tread that is causing the problems.
The other issue could be rim offset. I don't know what rims your Colways are on, but if the offset is more offset to the outside of the car (I cannot remember whether this is positive or negative offset?) then perhaps this will cause them to rub?
Some people claim that the Jimny is weaker than an SJ in the shafts/bearings area. My Jimny certainly gets through bearings like they are going out of fashion but I have yet to trash a CV joint on the halfshaft which is a symptom of running very large tyres and having a heavy right foot. I have never heard of anyone snapping a halfshaft as the CV joint goes first!. I have bent a rear halfshaft somehow. So I would say it was no real difference to my SJ410 in terms of needing continuous transmission maintenance, but note mine was a Spanish SJ410, not an SJ413.
ABS was an option on the earliest cars and standard on the latest. The problem with Jimny ABS off-road is not that its dangerous, but the ABS Coding wheels are fitted to the shafts and need to be smashed off to change the wheel bearings and as I said above, wheel bearing changing is a Jimny owners weekend hobby. Therefore on an ABS Jimny every wheel bearing change needs a new ABS coding ring - doubling the cost of the materials.
And, of course, send me pictures of anything you do!
Thanks
Thanks
16 Oct 2008 19:30 #223
by kirkynut
Replied by kirkynut on topic Re:M/T's on s standard Jimny and other Q's
Thanks for your quick response!
I had done the same maths as you and was therefore suprised at what I saw when I put the 195/80/15's on the Jimny as they should be 10mm slimmer but when laid out on the floor next to the 205/70/15, they simply weren't. Then factor in that they were, with the M/T tread about 1.5 inches larger in diameter, they were a great deal larger than I thought.
The tyres on the Jimny at the moment are the standard Suzuki issue Bridgestone Dueller road tyres and the M/T's , as I say are COLWAY remoulds.
It could be that I am looking at them with too much worry in my mind but I don't think so, they looked too big in the arches without a suspension lift being fitted. I couldn't do any tests to see if they catch as I don't think my partner's Mum would be happy with me ripping off the plastic arches from her 07 plate Jimny!
I thought about offset too. I can't remember which way - or + is either but it doesn't matter as I measured from the centre of the wheel, where it would toch the hub to level withe rim and measured this depth to be about 75mm on both wheels,give or take with my un-steady hand.
As such, I don't think it's a venture I'll be taking on.
I would like a jimny, I really would, but our SJ hasn't needed any new bearings yet and has been through some yucky stuff and done plenty of miles with me at the helm!
Thank you for re-assuring me about the half shafts, seems a shame about the CV's though!
Like I say, I want a Jimny and I want it to do what our SJ does, but it seems like it's a great deal more expensive and time consuming to run than a good old SJ. Shame the good old SJ ain't getting any younger though!
Thanks for all your help in answering my questions.
Rob
Rob
- ooky_123
24 Feb 2009 09:58 #386
by ooky_123
Replied by ooky_123 on topic Re:M/T's on s standard Jimny and other Q's
We used to run Collway remounld on our first Jimny no problem. with a 2" lift it was almost unstoppable, but equally with standard springs there was enough clearance for the 195's to turn even on full lock.
24 Feb 2009 14:42 #388
by kirkynut
I didn't risk it in the end and bought a ready modified Jimny with 215/15 Colway MT's on it already that have most of their life still in them.
When I put my SJ wheels and Colway 195/15 MT's on a standard Jimny they did look a bit tight in the arches but I couldn't experiment with rubbing properly as the standard vehicle was my girlfriends less than a year old jimny and she wouldn't have apprieciated it if it didn't work!!!
It's good to know from someone that has tried it that it does work. I don't think I'd like to run one like that though as even now with a 3" lift and 215/15's my radius arms get caught in ruts. I could get slightly bigger tyres I think but on the whole there's no need and the Colways are doing a good enough job to not justify spending money.
It's a shme Insa turbo Special Tracks don't come in 215/15's though.
- ooky_123
24 Feb 2009 14:52 #389
by ooky_123
haha. nice one.
My first Jimny was brand new (delivery mileage only) and had only done about 6,000 miles when we started to offroad her.
My Husband bought all the shiney stuff from Formula 4x4 in Stafford because he was workign in Liverpool and travelling twice a week.
the tyres were essential, and were soon followed by a 2" lift from KAP.
Driving with the Collway MT's was interesting but they did over 20,000 miles in the end by the time I cane to sell it.
We have just bought a set of Jimny wheels for £10 .. need to collect from Luton, and they will be shod with some Insa Dakar 195/15's.
Im trying to post some PIctures of the Jimny with the tyres / lift kit but Sky is playing up today.
Time to create page: 0.283 seconds
